Another dyno to alternator upgrade
/ Another dyno to alternator upgrade #1
WVUNUT1985
Good morning. I am seeking some advice and information from the TBN crew for this upgrade. I have spent the last week or so viewing the multitude of postings concerning the installation of an alternator in place of factory dyno. It seems one of the most common is on the "b" series Kubota. I am working on a Kioti LB1914 that has aux lights and warning lights for night work and for the most part has the same components as the kubota. I am installing a Hitachi 14231 alternator on my Kioti. I have the WSM for my tractor but the wiring diagram leaves a lot to be desired. I noticed that Kubota had a upgrade kit that included the new wiring harness and an additional relay. The Kioti uses the same external voltage regulator for the dyno conversion to DC voltage. Can anyone provide me the information on how this new harness is wired to by-pass the old external regulator and maintain feed to the glow plug timer and relay. Based on the information I have found on TBN, the six wires on the old regulator are reduced to only using two (which two is the question). The second part to this is, what is the new relay feeding voltage to and where is it wired to? Thanks in advance for the help.
/ Another dyno to alternator upgrade #2
by application the lb1914 shows to have a permanent magnet dyno should look like a pancake type of unit it was designed to produce enough power to charge battery and run a few lights it only produced about 13.0 volts and not much more in the amp output the o/e numbers maybe e5700-64014 you can swap these but first can you post picture of your unit for us to look at and from there we can advise what you can do next
I will post pictures tonight or tomorrow morning. Thanks
2019 CATERPILLAR 259D3 SKID STEER (A62129)
2019 CATERPILLAR...
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
429970 (A61165)
429970 (A61165)
Schulte SBW800 Rock Windrower (A61307)
Schulte SBW800...
2016 Chevrolet Silverado 1500 Single Cab Pickup Truck (A60352)
2016 Chevrolet...
