Another brush eater born!!
/ Another brush eater born!! #1
Robbie Hegwood
Platinum Member
Georgia
We'll gang, here's what I've been working on lately. It is a Yanmar SV-100 with our DAH-080C. We put this one together for Palmetto Brush and a few others. The excavator was spec'd at 37 gpm @3500psi. The tractor weights 20K. I was pleased with it's performance, nice and stable and good and capable. Mulched a 12" tree for fun. I will upload pictures of the stump next. I like this excavator for it's simplicity, hopefully would live a long and colorful life.
/ Another brush eater born!! #2
I guess it's a good idea. Maybe it will handle a bigger tree than a mulcher on a skid steer?? Maybe it can get to trees that a skid steer mounted mulcher can't?? What is really the additional benefit?
If I had an excavator I'd pull up the tree instead of mulching it.
A few more pics. As some of you know I'm not a little guy. That is a size 11 shoe for perspective.
/ Another brush eater born!! #4
Guess if you already have an excavator and just wanted to mulch instead of pull up the trees....but you still leave a stump??..
I dunno...call me stupid but it seems like the whole purpose in using an excavator for this type of work is to eleminate the stumps in the ground and this doesn't do that. I'd stiil like to know the benefit of this over a skid steer mulcher.
This setup is for a where skid steers will not and should not go. It will mulch on embankments, around lakes and dams. Also useful in retention ponds, all places you would not want to disturb the soil by pulling the root system. Plus you would have a hard time pulling up a 14" tree root ball and all with only a 20K machine. Also here if you disturb the soil it requires a permit and licensing. Depends on your mission.
/ Another brush eater born!! #6
robbie how much will this head cost call me 2517471802 chris with Mako Forestry,,,,and how much does it weigh.
/ Another brush eater born!! #7
how does this compare to the kubota 080 and also slope issues?
/ Another brush eater born!! #8
I guess I could add to this thread too..here are a few pics of what Robbie and I did when he came up here recently....
Robbie is actually only about 4'6 and weighs about 90lbs...don't let that pic of the sapling fool you! :D
This is a Tak TB175 putting out 3300 psi at around 22-23gpm...balances better than the 080..according to Robbie as I haven't run an 080...going to be hooking one up to a Terex TC75 soon as well pics to follow...
This is a good example of where you would want to use to Excavator instead of the Skid Steer
All three excavators are about the same on flow. I can tell the difference but most wouldn't. The Kubota does good, the Tak abit better with it's conventional tale, and the Yanmar is just beefy at 20K. The tak holds it's own with the least H.P. I was impressed with. The Yanmar for it's simplicity. And the Kubota has a good rep. I wouldn't sell one tractor for another, just buy one of our heads and blow everyone away!!! Ryan said it well about where to us an exxcavator.
And for slopes just drop the blade and level the turret and mulch. You can use our head while not running like a bucket and put it on the ground for stability.
/ Another brush eater born!! #10
How about a good close up photo of the cutting teeth.
It seems like that the most chipping heads were mounted horizontal with the boom. It also seems like the horizontal mounted head would be more versatile.
/ Another brush eater born!! #11
Yeah that excavator was really awesome i have ran the timber ax on the tak and it wouldnt run with the cimaf got some good video footage that im going to post
/ Another brush eater born!! #12
Nice looking machines.
I'm close to my first DC purchase. I'm 99% sure I'll be getting a 160 sized excavator and 125D...I was thinking 150E with a 200 sized machine but moving it would be too much trouble. The 160 is going to be my first machine and the ASV as back up for the jobs I have to have a skid steer for, such as thinning in tight spots. I think in the long run the 160 will be much cheaper to run.
I have a job with 46 acres of mixed sized harwoods from 6 to 10+ inches, I'm hoping to try out the DC there within 4 weeks.
After running the chipper blades on the Fecon going back to the carbides is painfully slow...
/ Another brush eater born!! #13
to add to what Robbie said...the CAT 308D and the Terex TC75 both have more flow and pressure than either the Yanmar, Kubota or Tak...can't wait to see how the Terex does soon...then I think a CAT install may be next (thanks again Robbie ;) )
/ Another brush eater born!! #15
Impressive! The video is a hair over a minute... How long was real life?
2020 Ford Explorer AWD SUV (A64557)
2020 Ford Explorer...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A65054)
2016 INTERNATIONAL...
2008 CATERPILLAR 242B2 SKID STEER (A65053)
2008 CATERPILLAR...
2013 Ford Taurus AWD Sedan (A64194)
2013 Ford Taurus...
