Thumb Another Back-Hoe Thumb
/ Another Back-Hoe Thumb #1
GEB
Goodrich IL
Branson 4720
Simple and cheap.
I welded a (1/4in wall) sleeve inside the stick for strength, IMO it's as strong
or stronger than it was....
I like my storage place also, it doubles as a 2nd pinch point, which I've
used many times in the past without the thumb there.
I think it will serve me well.
I made this out of scrap metal that I had laying around.
Total cost about $10 for paint and pins ;)
Gene
/ Another Back-Hoe Thumb #2
Now that makes sense. Clean appearance, quick to remove and strong enough to hold on to large boulders. That'll be one project I'll do on my backhoe. I give you an A++++.
/ Another Back-Hoe Thumb #5
The best $10 thumb i ever saw. better then some $1000 jobs.
Mike
/ Another Back-Hoe Thumb #6
Wow that is very cool
It's now on to to do list
Thank you
Thanks for the positive comments!
I might add some of the other nicer thumbs that I've seen
built here on TBN are very impressive!
Sad thing is this is so easy to put together any one with a welder is good to build one, so I cant see anyone buying a kit.....
Besides it takes a welder to install it.
So who's building the next one...will need some pic's.
And yes I got to give myself a little credit....
Gene maybe just short of Genius? :) J/K
Gene
/ Another Back-Hoe Thumb #9
I really like what you've done. Thanks for sharing.
/ Another Back-Hoe Thumb #10
Nice job Jeb! I built a traditional one, here it is. You will notice it is the same machine!
/ Another Back-Hoe Thumb #11
BobQ, have any more pictures or close ups of that?
mike
/ Another Back-Hoe Thumb #12
This is the only other one I have handy. Hope it helps!
/ Another Back-Hoe Thumb #14
Was the hole in the arm already their or did you have to cut it out. I really like the idea but I think the hole would make my small BH6000 a bit weak.
Good lookin thumb Bob, I think I seen it over on the Branson forum.
Gene
No, I cut the hole along with welding in a sleeve to add strength.
The thumb is a perfect fit inside top to bottom.
Maybe have a better look at the pic's.
If you have a smaller B/H maybe try using smaller tube?
My sleeve is 3inX1/4 wall thick the thumb is 2 1/2inX1/4 wall which makes a perfect fit.
As long as you use 1/4 wall tube it should be very strong even with smaller tube.
Hope this helps?
Gene
2000 Pro Stock Utility Trailer (A66285)
2000 Pro Stock...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
2012 MACK GU GRANITE 6X4 T/A ROLLOFF TRUCK TRACTOR (A59914)
2012 MACK GU...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
