And yet another JD 2520
   / And yet another JD 2520
smalltown,
Ours are not LED, when I was originally looking last year for our 2320 w/ 20 amp alt, I considered LED's. I found them to be expensive and the review by many (but not all) was they did provide the light a standard halogen does. Mine are JW Speaker Model 7100 floods. Below is the info if you decide to order through JD.
-Forward Light Kit PN LVB25546 (2 lights)
-Rear Work Light PN LVD25547
lost
   / And yet another JD 2520 #12
smalltown,
"Mine are JW Speaker Model 7100 floods. Below is the info if you decide to order through JD.
lost
RE the JW Speaker 7100's, they are offered with different bulb configurations, H9, 862 and 9005. The H9 outputs the most lumens. Which version did you buy and how do you like it? You said you purchased the "flood" version. Also, are all three lights (two forward facing and one rear facing) the same?
urban,
When I get home this evening, I will take a look on the bulb insert/mounts to see if there is an indication to which version of the 7100 I have. I assume you were looking at the spec sheet I have attached.
IMO more light is always better and I like the fact that I was able to use the existing 'plug and play' wiring harness. I also like that I am able to control these lights with the existing switch. I need the additional lighting for when I snowblow early in the morning or at night as the factory installed hood lights are partially blocked by the FM snowblower. Now, I may change my tune if I were doing extensive FEL work at night and wanted direct control of these lights. But my what I need to for right now...it suits my situation well.
I will get back to you tonight or tomorrow.
  • model-7100-4-x-6-oval-halogen-work-light.pdf
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
71058 (A49346)
71058 (A49346)
Great Plaines 2400 Tt (A50514)
Great Plaines 2400...
TEST YOUR BID BUTTON! (A51242)
TEST YOUR BID...
TAKEUCHI TB2150 EXCAVATOR (A51242)
TAKEUCHI TB2150...
(INOP) CATERPILLAR 416B BACKHOE (A50459)
(INOP) CATERPILLAR...
