Anchor stuff for bolts in concrete...
   / Anchor stuff for bolts in concrete... #1
DrDan
Ohio
G1800 & BX2200
A few years ago, I had some powder stuff that you mixed with water that anchored bolts in concrete floors. Forgot the name of it, but it wasn't hydraulic cement, I know that.
You drill a hole in the concrete then put the bolt head in to the base of the hole and pour this mixture in. It gets real hard in 24 hours. The alternative is lead and I don't want to get into that.
Any ideas what this machine mount stuff is?
DrDan
   / Anchor stuff for bolts in concrete... #2
Hi Dan,
I have a can of the stuff down at my shop... it sure made a believer out of me... stronger than the concrete curb I drilled in...
Tomorrow, I'll post the name of it...
   / Anchor stuff for bolts in concrete... #3
You can also buy expanding anchor bolts. Drill the correct sized hold, tap the bolt into place, and it locks to the hole as you tighten it up.
FWIW,
Dave
Thanks John,
Yes I know. That stuff is incredible! Lead anchors will vibrate out in time - not that "stuff"!
DrDan
   / Anchor stuff for bolts in concrete... #5
Rocktite?
Ed
   / Anchor stuff for bolts in concrete... #6
i have used rocktite and have used some steel reinforced epoxy (the grey looking stuff that comes in two film canisters) for smaller jobs. both worked well, and hardened overnight .
alex
   / Anchor stuff for bolts in concrete... #7
Could not find a website for Rocktite but here is the manufacturers address:
Hartline Products Co., Inc.
2120 S. Green Road, Suite 202
Cleveland OH 44121
Tel: 216 291-2303
   / Anchor stuff for bolts in concrete... #8
Hi Dan,
It's UGL Drylok cement that sets hard in "15 minutes" and useable in 2 hours... (either got it from True Value HW or WalMart... about 10 years ago)
<A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/8-206989-UGLDrylokCement-800.jpg>I set this back in 1991 or 1992... Believe me... it's tough stuff!...</A> /w3tcompact/icons/wink.gif
   / Anchor stuff for bolts in concrete... #9
HI DR DAN we use lead anchors but put vibration springs on the base of the equipment they work great
EDT
   / Anchor stuff for bolts in concrete... #10
<font color=blue>"It's URL Drylok cement"</font color=blue>
John,
You're spending way too much time online. That great stuff is UGL Drylock Cement. /w3tcompact/icons/wink.gif/w3tcompact/icons/smile.gif
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52706)
KNOW BEFORE YOU...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
90018 (A48082)
90018 (A48082)
2-Pallets Air / Discharge Hose (A53117)
2-Pallets Air /...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A53473)
2012 KINZE FLAT...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
