An Amish tractor? Say what?
   / An Amish tractor? Say what? #41
We were in Lancaster Pa last month, Amish farms are beautiful. The tractors I saw had home made steel wheels welded rebar on tread area.
They're hardworking nice people and I always get good deals on tools and hardware. Very serene and peaceful.
If anyone goes to New Holland , you have to stop at Yoders buffet restaurant not far from the blue tractor factory. 20191004_130404.jpg20191004_125722.jpg
   / An Amish tractor? Say what? #42
Amish around here are all Horse and Buggy, totally all old school the only more modern ones are by Hawley Mn at Spring Prairie where they (Hutterites)have a p/u they take to Fargo, they use tractors and they also have a electrical motor rebuild shop that a lot of folks use, they rebuild anything from starters for Honda Goldwings to Alternators/ Generators for tractors they do good work and when they go to town they always want to barter chickens and stuff for parts, seems they hate parting with what money they have. We did a fair amount of business with them or should say they did business with our store.
   / An Amish tractor? Say what? #43
Same where I live, ALL the Amish here have tractors on normal rubber.
SR
I suppose they could be foam filled tires...if air in tires is against their beliefs. Would look like normal rubber from a distance.
   / An Amish tractor? Say what? #45
Bishop did not say so. Order, structure, respect and preserving the culture and way of life are all things. Local control.
Preserving the culture......hence use of the Diesel engine. Got it...
   / An Amish tractor? Say what? #46
   / An Amish tractor? Say what? #48
I am catholic, or at least was born catholic, and I have much more respect for the Amish religion than I do the Catholic religion, although I believe all the precepts of the catholic church, how does one continue to have faith in the actual church after finding out all of the sins of its leaders?
While I never would defend what has happened in and has been covered up in the Catholic religion, I am sure the Amish have had their scandals, you just do not hear as much of it. Other religions as well have had atrocious behavior. Catholic coverups is what made theirs fester. No excuse for that carp.
   / An Amish tractor? Say what? #49
Your not the only one. I don't understand any of it. And my feeling are that if you have a belief then you need to stick with it. If you think tractors are bad, then tractors are bad. You don't stick stupid wheels on them and then allow them. You don't use battery tools because electricity is a bad thing. None of it makes sense, and the "slipping down the slippery slope" and changing you "beliefs" because they are more expedient seems hypocritical to me.
Ok, you can have a gasoline engine powered baler, but it has to be pulled by horses and have a stationary engine. NO. If engines are bad ALL engines are bad. And if power tools are bad ALL power tools are bad. If telephones are bad, then ALL telephones are bad. You can't have one outside in the rain.
Jeez...Hold to your beliefs or change your beliefs. Don't do things half axed, and make concessions to reality. Oh sure a nice JD tractor and now you have to wreck the tires.. yeah, that will keep you on the "straight and narrow". Uh huh.
But what do I know. People do stupid things. I have done a few myself.
As I understand it, you are supposed to be "plain and simple" without "frivolities"
Air filled rubber tires are seen as frivolous as the air is to "give you a better ride". Hence steel wheels (or steel wheels with rubber tread), horses and buggies, etc.
As for phones and electricity, they are not supposed to be dependent on the world, hence a cordless tool battery powered light, or a diesel motor/generator to run your milk cooler, power your workshop, etc because you aren't tied to the world like you would be with a monthly electric bill.
In some cases, the rules are different for a business (ie: a business can have a prepaid cell phone, a computer and a internet connection, etc but it need to be "in the business" not in the home).
What is and isn't allowed depends on the board of Elders for that congregation, hence some allowing rubber tires tractors to run a baler, others allowing steel tired tractors whole others require a horse drawn power cart and yet others require a stationary baler.
We have had some who were honest, some who weren't, but overall have had good luck with the people we have worked with.
Aaron Z
1998 POLAR TANK CRUDE TRAILER (A55745)
1998 POLAR TANK...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
40' CONTAINER (A51244)
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2013 Ford F-150 Ext. Cab Pickup Truck (A53422)
2013 Ford F-150...
