An Accessory for your Lock-N-Lube grease coupler
   / An Accessory for your Lock-N-Lube grease coupler #21
UPS was very good to me today! Locked and loaded! (pun intended :laughing:)
I got the exact same combination recently because of the recommendations here on TBN. I see why folks like the LockNLube. I don’t currently have a need for angling the end, but I’ll definitely file the idea away for the future.
   / An Accessory for your Lock-N-Lube grease coupler #22
I never heard of the Lock N Lube before but it looks very useful. I think I'll have to order one.
   / An Accessory for your Lock-N-Lube grease coupler #23
Finally got my Lock N Lube on the gun today at work. Had to use a vise due to the original being on so tight I had no chance at home with my basic tool (and skill) set.
Did notice when I brought it in to use the vise that when I opened the case, I had grease streaming out of the relief or bleed/purge valve. Not sure what that is about so I'll break open the manual tonight. Unless someone can tell me what I did wrong and need to do to correct.
   / An Accessory for your Lock-N-Lube grease coupler #24
Is the purge valve closed? It only needs to be opened when changing grease tubes.
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
Suzuki Vision Quad Runner 500 (A55272)
Suzuki Vision Quad...
Mini Excavator Bucket (A55272)
Mini Excavator...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
2020 Deere 325G (A57148)
2020 Deere 325G...
