An Accessory for your Lock-N-Lube grease coupler
   / An Accessory for your Lock-N-Lube grease coupler #11
   / An Accessory for your Lock-N-Lube grease coupler #12
Thanks to you and k0ua, I just ordered DeWalt 20V grease gun and the standard LNL. Now to figure out where all my zerks are located.
Boys, no "stealing" necessary. It is free for all!. :D
   / An Accessory for your Lock-N-Lube grease coupler #15
James - Do you use the same brand/type grease on your DK or do you use whatever you can find at the time, etc? I'm not a grease expert....
And yes... All that to say, what grease do you use? :cool:
   / An Accessory for your Lock-N-Lube grease coupler #16
UPS was very good to me today! Locked and loaded! (pun intended :laughing:)
   / An Accessory for your Lock-N-Lube grease coupler #17
I have the the short Lock&Lube and the long-ish one to, but at times or everytime that long-ish Lock&Lube is not long enough. I have two fittings, one I get under the tractor and the other one between the skid plate and tractor, I now need a 12" long L&L or something 12" long for those two grease fittings on my brake pedal. Then I also need something for a 45° angle for the one on my clutch pedal, these 3 fittings take longer to grease than all the other fittings on the tractor. What's needed is a zerk grease fitting kit for hard to grease places for $19.99.
   / An Accessory for your Lock-N-Lube grease coupler #18
A guy who does forestry mods on tractors here in my town has a solution for hard-to-reach grease zerks (since his mods sometimes create a problem with zerks): he mounts the zerks remotely. He removes the zerk and connects metal tubing where the zerk was, routes the tubing out to where it's easy to reach, and puts a zerk on the end of that. I've not looked closely to see what fittings he uses.
I have been using the red grease at Wal-Mart. I like it because it is not so nasty as the black grease that contains Moly. Yeah Moly is good, but man don't ever get any on your clothes. I grease often, and sooner or later you are going to get some grease on your clothes.
   / An Accessory for your Lock-N-Lube grease coupler #20
we use the black grease at work and I can't even walk past a tube with it getting on me. we also use the red high temp grease I like it for just about everything.
2018 Chevy Silverado 1500 4X4 (A56438)
2018 Chevy...
Giyi Mini Grapple (A57149)
Giyi Mini Grapple...
JOHN DEERE BA84 WORKSITE PRO ANGLE BROOM (A54757)
JOHN DEERE BA84...
John Deere 6ft Rotary Brush Cutter Tractor Attachment (A56857)
John Deere 6ft...
1999 CPS TRAILER COMPANY BELLY DUMP TRAILER (A58214)
1999 CPS TRAILER...
2014 MACK CHU  PINNACLE DAY CAB (A55745)
2014 MACK CHU...
