An Accessory for your Lock-N-Lube grease coupler
   / An Accessory for your Lock-N-Lube grease coupler #11
   / An Accessory for your Lock-N-Lube grease coupler #12
Thanks to you and k0ua, I just ordered DeWalt 20V grease gun and the standard LNL. Now to figure out where all my zerks are located.
Boys, no "stealing" necessary. It is free for all!. :D
   / An Accessory for your Lock-N-Lube grease coupler #15
James - Do you use the same brand/type grease on your DK or do you use whatever you can find at the time, etc? I'm not a grease expert....
And yes... All that to say, what grease do you use? :cool:
   / An Accessory for your Lock-N-Lube grease coupler #16
UPS was very good to me today! Locked and loaded! (pun intended :laughing:)
   / An Accessory for your Lock-N-Lube grease coupler #17
I have the the short Lock&Lube and the long-ish one to, but at times or everytime that long-ish Lock&Lube is not long enough. I have two fittings, one I get under the tractor and the other one between the skid plate and tractor, I now need a 12" long L&L or something 12" long for those two grease fittings on my brake pedal. Then I also need something for a 45° angle for the one on my clutch pedal, these 3 fittings take longer to grease than all the other fittings on the tractor. What's needed is a zerk grease fitting kit for hard to grease places for $19.99.
   / An Accessory for your Lock-N-Lube grease coupler #18
A guy who does forestry mods on tractors here in my town has a solution for hard-to-reach grease zerks (since his mods sometimes create a problem with zerks): he mounts the zerks remotely. He removes the zerk and connects metal tubing where the zerk was, routes the tubing out to where it's easy to reach, and puts a zerk on the end of that. I've not looked closely to see what fittings he uses.
I have been using the red grease at Wal-Mart. I like it because it is not so nasty as the black grease that contains Moly. Yeah Moly is good, but man don't ever get any on your clothes. I grease often, and sooner or later you are going to get some grease on your clothes.
   / An Accessory for your Lock-N-Lube grease coupler #20
we use the black grease at work and I can't even walk past a tube with it getting on me. we also use the red high temp grease I like it for just about everything.
VERMEER FEED ROLLER (A58214)
VERMEER FEED...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2017 Freightliner MT55 Step Van (A56858)
2017 Freightliner...
2014 Dodge 5500 4X4 Bucket Truck (A55302)
2014 Dodge 5500...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
2010 International Derrick Digger (A55973)
2010 International...
