amperage for starters
Status
Not open for further replies.
/ amperage for starters #21
lakespirit said:
Curiosity.
Not well. Many theories, but so far, I still don't have a presseure gaurge, so I am only providing partial data to get the proper help.
If you are curious about the amps required to start your TS254, you should buy an amp meter that connects between the battery post and the cable leading to the starter. They only cost about $125-$250, depending on the amp rating of the meter. To be safe, you should buy an amp meter with the largest rating you can get because the amp flow when starting a diesel engine measures in the hundreds of amps.
If you do this you can disregard all of the posts about "Ohm's Law" and get the amp reading you are so curious about.
I am beginning to smell old fish in your posts.
/ amperage for starters #22
greg_g said:
Actually Jeff has a 254, which is one size smaller than the 300 series. Not terribly important though, same size battery tray in both. I can't tell however - from your profile - if you even own a Chinese tractor, so you may not realize how physically large the OE battery is in the first place.
I replaced one of my JM254 batteries with an Interstate MT-49 (940CA/750CCA) made for Mercedes diesels. And I replaced one of my KAMA batteries with a MTP-93 (same case, higher output). Don't have a clue as to the Chinese battery amperage rating, but I seem to recall the 14"x7"x7" Interstates are physically a little smaller than OE.
But as large as the Jinma/KAMA/TaiShan battery compartments are, I don't think they'll quite accommodate a 20"x8"x8" 4DLT. Might get one in a Foton though. Their battery compartments are sized to accommodate a pair of pretty good sized 6v batteries. It's all a bit academic to me anyway, since the MTP-93 and 4DLT have the same basic 1000CA/850CCA rating anyway.
//greg//
So I mis-typed.
What does all of this information have to do with the starting amperage of lakespirits KAMA 254?
I have a KAMA 354 and it has two 6 volt batteries in separate trays and are connected in series to produce 12 volts.
/ amperage for starters #23
Creekman said:
What does all of this information have to do with the starting amperage of lakespirits KAMA 254? I have a KAMA 354 and it has two 6 volt batteries in separate trays and are connected in series to produce 12 volts.
What's with the attitude? And since you already have a Chinese tractor (with two batteries in the compartment), it's now curious why you thought it necessary to ask " How big of a battery do you think lalespirit can cram into a KAMA TS354?? ".
I'm beginning to smell an agitator behind your posts.
//greg//
/ amperage for starters #24
[[[I am beginning to smell old fish in your posts.]]]
[Yeah really.]
Shop around and you can get an AC/DC Clamp-on Ammeter with voltage function included for that price range. You just clamp the jaws of the meter aroung the wire and read the current.
larry
/ amperage for starters #25
I bought a set of these inductive ammeters (MT1009) quite some time ago for about 50 bucks and are capable of getting that reading your interested in.
I'll slip some shoes on and go see what my 790 draws.
/ amperage for starters #26
Crank time was only about 2 seconds and it jumped around a bit, but it was definitely in the 300-350 range.
/ amperage for starters #27
Willl said:
Crank time was only about 2 seconds and it jumped around a bit...
If so equipped, pull the fuel cutoff while cranking, and put the DMM on peak hold.
//greg//
/ amperage for starters #28
Ditto that... a decent clamp on meter with a peak hold would be a good choice for these large current situations.
soundguy
/ amperage for starters #30
Willl said:
It's not a DMM.
There are plenty of dmm/dvm mm'S VOM's.. etc.. that have a clamp on function.. it don't matter it yours was a dvm or the little snap on job.. the advice is the same. the benefit of a peak reading hold is to see what it really gets up to, for comparison sake..e tc.
soundguy
/ amperage for starters #31
SPYDERLK said:
Yes. Motor resistance is very low. If you applied Ohms law to the actual motor resistance you would predict extremely high currents. This resistance doesnt change as the motor spins, but as the motor spins it generates a counter V [opposite from the batt V] called Back EMF. As the motor goes faster so rises BEMF until current limits. - So the resistance of the motor appears to vary with speed. Slow the motor with a load, BEMF drops and current rises. As current rises there is more V lost due to the internal resistance of the batt so the V remaining to feed the motor goes down. The current to a starter is way high at low cranking speeds in cold engine starting applications regardless that the battery may be consuming 2V internally and only delivering around 10V to the starter.
Very few tractor sized 12V batteries will hold up to deliver 12V to a 100+ Amp load-NONE will deliver 13.2V . Thats why I used the 11.5V figure for predicting current consumed by a 2.2kW starter.
larry
Yeah, yeah, mumble, mumble, back emf, rising internal resistance of the battery as it drains, falling of back emf as the starter slows, etc......
Which is why I used the word UNPREDICTABLE.
At the instant the switch is thrown ohm's law pretty much applies, self and mutual inductance will follow, soon, but not at the instant of initial contact.
Have enough cable to take the full stalled load, not the load at free spinning speed.
/ amperage for starters #32
//greg//
you dont want to use peak hold until actually cranking, cuz that will give you the instantaneous locked rotor current before the motor starts to spin. Interesting in that it will be the max current youll ever see in the system, but little relation to actual cranking current. Just pulling the fuel cutoff like you said will do good for a cranking current - and then during cranking you can do peak hold and get the peak caused by compression strokes.
larry
/ amperage for starters #33
No point in using the huge cables necessary to support a stalled load. The stall is over as soon as the motor spins up. Amperage drops to a fraction of the stalled Amps. Not UNPREDICTABLE.
larry
/ amperage for starters #34
good point - I guess I should have been more specific
//greg//
/ amperage for starters #35
These are the exact ones I use. I have the high dollar clamp-ons for my DVM's. Don't like them. Reaction time is too slow. My DVM's are not cheap ones either. I have 2 Flukes, a Beckman and a Greenlee. There is nothing like the real time reading of an inductive ammeter like the MT1009 style.
/ amperage for starters #36
larry
The stall is only over IF the starter motor spins up.
If you ENJOY electrical fires by all means connect up with wire that is barely adequate. Your choice.
MY preference is to plan for the worst case, but hope for something less bad.
UNPREDICTABLE, as in too many variables to derive a reliable value.
/ amperage for starters #37
When I hit the key I note that the engine is accelerated to cranking speed almost instantly. So the stall condition has ended even quicker than that. If the engine does not turn I dont spend much time in Duh mode - I let off the key. In either case the high current condition of around 1000A at stall ends plenty quick to obviate the need for cable that would support 1000A steady state. If I did have 1000A cable and became frozen in Duh mode with a locked engine or starter, there would still be starter fires and battery explosions to worry about. But I predict that standard cables, batteries, starters, and observation of whether the engine is turning will serve well enuf.
larry
/ amperage for starters #38
Reg said:
At the instant the switch is thrown ohm's law pretty much applies, .
Ohms law applies no matter what.. just have to take the circuit into account. remember on an inductive circuit, you get to mess with stuff that looks an awfull lot like impeadance,.. vs plain dc resistance. you also get to play with inductive reactance.
In this circuit, the moment the switch is thrown, voltage will lead current / current will lag voltage.
soundguy
/ amperage for starters #39
larry
the more conductor betweent he source and load the better.. at some point you hit diminishing returns.. but 'adequate' is never 'ideal' when it comes to battery cables.
12v auto's can get away with 4ga cables. diesel and 6v application like 0/00 thumb thick cables... more copper never hurts.
Rremember.. small copper between a battery and a starter = a shunt and a votlage drop
soundguy
/ amperage for starters #40
soundguy
Dont forget cable length. You just want to limit Watts lost in the cable. Shorter cables can be smaller. When you have cables 5 or six or more feet long theyd better be big - especially where it gets cold.
larry
Status
2014 Chrysler 200 Sedan (A66738)
2014 Chrysler 200...
2011 TRAIL KING TK70MG-523- 52' LOWBOY TRAILER (A65054)
2011 TRAIL KING...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
2007 WEEKEND WARRIOR BUMPER PULL (A67714)
2007 WEEKEND...
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
