American International Brush Hog
/ American International Brush Hog #1
VTB
Vermont
NH TC29
Recently I've seen a couple people selling new brush hogs that are red in color and seem to be pretty sturdy. They say they are American International. I can't locate anything online about these BHs. Do any of you know anything about them? The price seems right but not sure what the deal is with them. Thanks very much!
/ American International Brush Hog #2
Most likely they are IMC (International Machine Co.). They are sturdy and red. I have the 7 ft and a 5 ft from IMC. Very satisfied with the units. BobG in VA
/ American International Brush Hog #3
how much would one of these be worth in a 4 ft. I think I found a good deal but haven't heard of this brand. Also how hard is it to find parts for this brand??
/ American International Brush Hog #4
Bullzibart, I bought a new IH400, (4' Int. Brand) late last winter from a local dealer. I believe there was a parts breakdown in my little manual. The fit and finish is not as good as say a Woods but the price was right for occasional use. The company is in Bethel, Ohio and they still make them so I would "assume" parts shouldn't be an issue. A new one here in So. ME runs about $795 in season.
/ American International Brush Hog #5
I have a 16' trailer that is an International brand and it was made in Ohio....I bet we are talking about the same company....
/ American International Brush Hog #6
Some of the local dealers sell International brand of hogs for around $600 for a 6 footer.
/ American International Brush Hog #7
I just picked up the 4 footer last night. It needs a little welding to help the looks a bit but other wise its in great shape. It will need a coat of paint but for 325 I dont' think it was a bad deal.
/ American International Brush Hog #8
Bullzibart, I think you'll like the IH. Let me know if you need info on it and I will try and scan part or all of the manual and .pdf it to you. That is a good price. All the used ones I found, Woods, mainly for that price, were 15-20 years old, pretty well beat to death and had so much rust on them that I just walked away.
/ American International Brush Hog #9
MajMac thanks alot for letting me know that was a fair price. It has been stored out side so it is rusty but appears to be only surface rust. Nothing alittle paint can't take care of. At some point I'll need some info on it so I can get parts. I'm pretty sure I'll need blades right off. Do you have a part number for them??
/ American International Brush Hog #10
I'll try to remember to look that up tonight or tomorrow when I am home. The way I'm cutting up rocks I may need a pair!!
/ American International Brush Hog #11
Thanks again... I believe its a IH 400 not 100% sure. Going to pick it up tonight after work.. Hopefully have it up and running this weekend.
MajMac, It is the same brand as in your photos, but I got the 5'. Seems to be ok. I hooked it up just fine and initial test runs through the pasture worked fine. But, when looking at it in the barn yesterday, I notice the two connector bars on the 3-point hitch are bent subtantially. Not sure how I did that. Didn't hit anythig hard. Hmmmm....
Also, I'm having a brain lapse and can't seem to remove the plastic PTO cover to get at the bolt securing it to the Gear Box.
It's the same PTO shaft that's in your picture. Any help would help!
Thanks a ton....
/ American International Brush Hog #13
VTB, I haven't taken the plastic sleeve off yet so I'm not sure. I've wondered though because I think the u-joint has a grease fitting and I've not sure either how to remove the plastic. I copied the Op. manual to a .pdf at work today but this site kept telling me the thing was to big a file. It is only 408K or so, not big in my mind but I was unable to attach it.
/ American International Brush Hog #14
Can anyone tell me how to attach a file to a post. When I try, even a small file, 408K .pdf, it tells me it is to big. I sent an email to "Contact US" but no reply. Thanks in advance.
/ American International Brush Hog #15
MajMac do you have a website for them? I can't seem to find anything about them online.
I looked at your brush hog in the photos and mine is alot different. You have the two supports that run from the 3pt. hitch back to the rear. Mine has what looks like a piece on leaf spring with a small amount of chain on the end.
I hope you can figure out how to attach that file, and I hope it will help me some.
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
SQUARE FUEL TANP & HAND PUMP (A63291)
SQUARE FUEL TANP &...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
INTERNATIONAL 4900 GRAIN TRUCK (A63291)
INTERNATIONAL 4900...
