Backhoe Amerequip - backhoe OEM to Who ?
   / Amerequip - backhoe OEM to Who ? #1
Reg
Elite Member
Basically the title is the question, who do they "make and paint" their hoes for ?
I have one, the 8 1/2 ft., I would like to know where else I could shop for parts, in particular buckets, maybe a thumb, etc.
   / Amerequip - backhoe OEM to Who ? #2
Check against JD. I found out they made the valve system for my 448
Thanks,
I asked at the local JD parts counter today, they seemed to think that the Sales folk MIGHT know the origin of the Frontier hoes.
I didn't bother (-:
Another lead from Rick Rinehardt at Everythingattachments.com suggested Bush Hog and sure enough when I looked at the owner's manual on their site it pretty much matches mine - apart from a few cosmetic things and a couple of specifics on hooking the hydraulics into a BH loader power beyond, etc.
So just in case anyone else is interested; a Bush Hog 8500 is essentially a Century C86, is an Amerequip 8600, is an (dunno what else)
Cidertom,
It turns out that Amerequip made the WHOLE 448 hoe for Deere.
So, I measured a 448 Deere bucket at the local AWE_THEN_TICK Deere dealer yesterday; check, pin diameter, length, spacing matches - then I priced it.
OUCH ! It will be a while before I shop there for parts.
Montana is another one and for me that dealer seems to be the best combination of 'close to home' and "non-premium price".
BTW, Branson is another one.
ONLY 8 years later and it seems I will be needing some Amerequip (or equivalent) parts.
Brief description; there is looseness/slop/play at the base of the boom.
Until I get it apart I am assuming that there is wear in the pins/bushings that the boom hinges up/down on.
Anyone here ever taken one of these apart for such work ?
My guess is that everything is heavy and I will have to lay it out, i.e. extend the boom and dipper stick, maybe then roll it on its side.
My workshop will have to be my back yard and I will probably have to use the FEL for any heavy lifting.
I have a few jack stands, floor jack, bottle jack, etc.
Should I just take it to a farm equipment repair shop and PAY, or is this realistically a DIY job for someone with limited shop facility ?
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2014 FREIGHTLINER...
2012 BMW 328i Coupe (A56859)
2012 BMW 328i...
2012 GALLEGOS 130 BBL STEEL VACUUM TRAILER (A58214)
2012 GALLEGOS 130...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
