Ambra G 134
   / Ambra G 134 #1
Jefferson60
Gettysburg, Pa
Kubota
I used this for the 1st time yesterday and found what appeared to be dirt or sediment at the bottom of the jug, I went back to the NH dealer and we opened a 2nd jug and it was the same. Is it normal for there to be what appears as sediment in the bottom of a jug of Ambra G 134? Both jugs had the seal intact.
Regards,
J60
   / Ambra G 134 #2
The containers were setting for awhile and the additive separated some which is normal. I shake all my oil jugs before opening and using the oil.
   / Ambra G 134 #4
I don't know if it's 'normal' for this fluid but even so it is not correct. The fluid should not separate, if it does then there is something wrong with the stability of the formulation.
   / Ambra G 134 #5
I've noticed the described sediment in 5gal buckets of engine oil as well.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2018 CATERPILLAR 950GC LOADER (A51246)
2018 CATERPILLAR...
2012 CATERPILLAR D6T XW HI-TRACK CRAWLER DOZER (A51406)
2012 CATERPILLAR...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
