Ambra G 134
   / Ambra G 134 #1
Jefferson60
Gettysburg, Pa
Kubota
I used this for the 1st time yesterday and found what appeared to be dirt or sediment at the bottom of the jug, I went back to the NH dealer and we opened a 2nd jug and it was the same. Is it normal for there to be what appears as sediment in the bottom of a jug of Ambra G 134? Both jugs had the seal intact.
Regards,
J60
   / Ambra G 134 #2
The containers were setting for awhile and the additive separated some which is normal. I shake all my oil jugs before opening and using the oil.
   / Ambra G 134 #4
I don't know if it's 'normal' for this fluid but even so it is not correct. The fluid should not separate, if it does then there is something wrong with the stability of the formulation.
   / Ambra G 134 #5
I've noticed the described sediment in 5gal buckets of engine oil as well.
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
(APPROX. 15) UNUSED IRANCH GROUND PROTECTION MATS (A54757)
(APPROX. 15)...
