Ambra G 134
   / Ambra G 134 #1
Jefferson60
Gettysburg, Pa
Kubota
I used this for the 1st time yesterday and found what appeared to be dirt or sediment at the bottom of the jug, I went back to the NH dealer and we opened a 2nd jug and it was the same. Is it normal for there to be what appears as sediment in the bottom of a jug of Ambra G 134? Both jugs had the seal intact.
Regards,
J60
   / Ambra G 134 #2
The containers were setting for awhile and the additive separated some which is normal. I shake all my oil jugs before opening and using the oil.
   / Ambra G 134 #4
I don't know if it's 'normal' for this fluid but even so it is not correct. The fluid should not separate, if it does then there is something wrong with the stability of the formulation.
   / Ambra G 134 #5
I've noticed the described sediment in 5gal buckets of engine oil as well.
2025 GREAT DANE FLP-0024-00053 53FT SPREAD AXLE FLATBED (A54607)
2025 GREAT DANE...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
