Am I missing something
   / Am I missing something #11
Thanks for all the help I will try all of the above, one of them should work. Some of these glitch solutions, push violently, turn the wheels back and forth, make it look like some of Kubota's engineers have been and are asleep at the wheel.
Tough to get a recall on a tractor!!
It is not so much a violent hard push as it is a violent rapid push. forward/up on your control. Don't tear off the joystick, just "snap" it forward past the detent.
James K0UA
   / Am I missing something #12
^ What he said..^You go to slow you end up lookin up.
   / Am I missing something #13
I'd suggest you play with it with the engine off and bucket on the ground first, nothing will happen with the bucket but the valve will still go into float position. With yours you push the joystick firmly forward (as if to lower the loader arms). When you reach the end of the spring loaded travel, push a bit further and you'll feel the valve go past a detent and stop. That's float. Once you get a feel for it, start the engine and try it. Did you check the loader manual?
Sean
   / Am I missing something #14
"glitch solutions" "Turn the wheels back and forth" ...Recall"
What are you talking about? Nothing is wrong with the tractor. :confused:
Thanks all, it does take a hard push up to lock it in. Hope it will loosen up with use.
   / Am I missing something #16
That is good to hear!
It should take a hard push, so it will not go into float when in regular use.
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
2015 ISUZU NRR 20FT BOX TRUCK (A51222)
2015 ISUZU NRR...
CATERPILLAR 962M LOADER (A51242)
CATERPILLAR 962M...
2020 INTERNATIONAL LT625 DAY CAB (A51222)
2020 INTERNATIONAL...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
Backhoe Attachment (A50322)
Backhoe Attachment...
