Aluminum D Rings ?
/ Aluminum D Rings ? #1
Tomtint
Elite Member
Boston
L3700SU
I'm getting a new dump truck this week and decided to go with a aluminum dump body.. primarily to eliminate the rust problems we have in the North East and also to save weight capacity. I'm going to have a salt sander I. The bed during the winter months and needs to strap it down. In the past, I have had d rings welded inside the steel dump body's and it was fine. Not sure if aluminum is strong enough to do such a thing. I'm guessing the pulling pressure on each ring with ratchet straps may be 1000 pounds +\-.. but again that's just a guess. Anyone done this before with aluminum ?
/ Aluminum D Rings ? #3
What is used to anchor heavy vehicles in aluminum cargo planes?
Bruce
/ Aluminum D Rings ? #4
Bruce
Cargo airplanes usually use a deck mounted track system, with many lock points, not "D" rings.
That's what I figured. Kind of like a E track type set up but much stronger. I googled and looked at some pics. I noticed some people have welded on a 1/4" p,ate on top of the existing surface and then bolted D Rings through 1/2" of aluminum.
/ Aluminum D Rings ? #6
I think aluminum d rings would be plenty strong enough. I’m assuming you’ll have them welded in? They are used on aluminum trailers all the time and I haven’t heard anything negative
Brett
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
Preliminary Listing / Full Catalog Coming Soon! (A62177)
Preliminary...
2018 Bomag BC572 Articulated Refuse Compactor (A64553)
2018 Bomag BC572...
2015 Ram ProMaster 1500 Van (A62613)
2015 Ram ProMaster...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
