alternitive hyd oil
   / alternitive hyd oil #1
jdjunk
Lancaster, PA.
2000 JD 4200 hst
Is there any other hyd oil, other then John Deeres brand that I csn use in my 4200 with the
hydrostatic transmission.
Thanks, Tom
   / alternitive hyd oil #2
Thanks, Tom
I'm sure you can find an alternitive, but I don't think you'll save much, if you use the JD stuff you know for sure it's good for your tractor.
   / alternitive hyd oil #3
Tom, welcome to TBN. Sure there's alternative hyd oil that meets the OEM specifications per John Deere.
Look for the grease-lube/oil/hydraulic fluid requirements in your owner's manual and match those specifications with whatever product you're considering.
If it meets those specs - you're good to go!
There's a number of post's on the Oil, Fuel and Lubricants forum here on TBN regarding the unending "pros and cons" of the various brands.
Hours and hours of "listening pleasure"...
AKfish
   / alternitive hyd oil #4
Hi and welcome,
I've tried several oils including Amsoil synthetic. I found the best oils were the Deere oils. I don't know who makes them for Deere but they perform very well.
Rob
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 66"...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
