alternitive hyd oil
/ alternitive hyd oil #1
jdjunk
Lancaster, PA.
2000 JD 4200 hst
Is there any other hyd oil, other then John Deeres brand that I csn use in my 4200 with the
hydrostatic transmission.
Thanks, Tom
/ alternitive hyd oil #2
Thanks, Tom
I'm sure you can find an alternitive, but I don't think you'll save much, if you use the JD stuff you know for sure it's good for your tractor.
/ alternitive hyd oil #3
Tom, welcome to TBN. Sure there's alternative hyd oil that meets the OEM specifications per John Deere.
Look for the grease-lube/oil/hydraulic fluid requirements in your owner's manual and match those specifications with whatever product you're considering.
If it meets those specs - you're good to go!
There's a number of post's on the Oil, Fuel and Lubricants forum here on TBN regarding the unending "pros and cons" of the various brands.
Hours and hours of "listening pleasure"...
AKfish
/ alternitive hyd oil #4
Hi and welcome,
I've tried several oils including Amsoil synthetic. I found the best oils were the Deere oils. I don't know who makes them for Deere but they perform very well.
Rob
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
2016 HAMM HDT90IVV DOUBLE DRUM ROLLER (A64279)
2016 HAMM HDT90IVV...
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
2021 CATERPILLAR 306 CR EXCAVATOR (A64279)
2021 CATERPILLAR...
