Alternator?
/ Alternator?
Good news on this one! I went to the dealer and they were able to help me out. Problem solved! These guys are great. Anybody in North Georgia, I highly recommend Georgia Land Equipment in Cumming, GA.
/ Alternator? #23
Hi please elaborate on what they did. I have a 2015 4520c thats putting out 20v at the battery. Not sure if there is a voltage regulator or if its inside the alternator.
thanks!
/ Alternator? #24
thanks!
What we call a "modern alternator" (vs generator) has a self-contained regulator which controls the current in field windings to limit power output.
Generators spin wire-wound coils (rotor) inside permanent magnets. Power output increases the faster the rotor turns. A brute force external regulator is used to discard the excess. Engine HP used to produce the excess electric power is also lost.
Modern alternators are most correctly called "excited field alternators". Permanent magnets replaced by electromagnets. DC field current from the battery running through coils to produce the magnetic field in which the rotor spins to produce electricity. The elegance of this design is how the DC field current (usually 1/50th of the alternator's output) can be regulated to control the alternator output. The alternator never produces more than needed. The alternator only loads the engine according to your electric power needs.
Diesel-electric locomotives use the same excited field alternator to control speed. Diesel drives alternator. Engineer controls current in the field to control how much power is generated and fed to the traction motors. Gear drive is more efficient but could you imagine having to use a clutch to get a train moving? And then how many gear ratios in your transmission?
/ Alternator? #25
So it’s looking like an alternator replacement then. $442 from one place just for the part. Anyone know if alternator is repairable
/ Alternator?
thanks!
Sorry, I wasn't paying attention for a little while.
We worked out an arrangement for a replacement.
/ Alternator? #27
I find it fantastic to believe someone cast a custom alternator with mounting points unlike any other just for a few tractors.
Don't know where one would find a table to alternator dimensions to compare yours to interchange with something more available. Might be easier to build a new mounting bracket for a commonly available alternator.
/ Alternator?
I would think your best bet would be to take the alternator to an auto electric shop to see if they can repair it. If so, I would think that would be much cheaper than replacement.
/ Alternator? #29
Just wanted to say Rich and team have been fantastic to work with me on my tractor!
/ Alternator? #30
I'm chasing alternator problems on mine...also a 4520C, 2015 model year. Mine hits 20v, the alternator tests fine at a repair shop I found. There isno tractor indication of trouble, I found it when the tractor needed a jump and I started measuring voltage at the battery. There should be a single wire connection on the back that is for the tachometer I think, I don't see it in your pic. Did you measure the battery terminal voltage while running?
/ Alternator?
I didn't do any measurements. The only indication of a problem was that the tachometer quit working.
/ Alternator? #32
On mine there is a single tab / wire I think is for the tachometer. Anyway mine was user error by me using a cheap multi meter giving me false high voltage readings.
/ Alternator? #33
I have a 2018 4520C and it looks like the alternator has died. The tachometer stopped working but I still had work to do so I ran for two days. Then the tractor stalled and the battery didn't have the juice to start it. Never had a warning light but that's how it looks. Jump started and got it back to the house.
Now I'm searching for a replacement and can't find one anywhere. Anybody got any idea where to get one?View attachment 703660
Howdy sir. I have the same alternator on my 4015. Can u tell me or send pic of how u hook it up. Not sure the wire from the harness goes. And were the big ground wire goes. Thx for ur help
/ Alternator? #34
If all else fails you might find a compatible cross referenced alternator at DB Electrical (USA made). If the form, fit, and function works who cares what name is on the label plate. Good luck. Regards.
/ Alternator? #35
has anyone found an after market one that works for this ?
10000LBS Two Post Automotive lift (A64194)
10000LBS Two Post...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A64556)
2016 Volvo VNL T/A...
2013 Caterpillar Warren Power Systems WCW84MH 8KW Portable Light Tower (A64194)
2013 Caterpillar...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
TAYLOR 2R MULTI-PASS HARVESTER (A64278)
TAYLOR 2R...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
