alternator
/ alternator #1
cowpens
Mandra 55004wd
Replaced the battery on 5500 mahindra. Alternator not working now.
/ alternator #3
Out put voltage at B+ terminal of alternate when proper charging should be 14 volts (+/- 0.2 volts).... IF not alternator has a problem... If there is a regulator associated with alternator it could possibly be problem...
Also check if system has a ALT lamp. some systems require a shot of 12 volts through ALT lamp to initialize charging, if lamp is burnt out it may effect how alternator operates....
/ alternator
The light was not coming on before. Not sure about the voltage but will check. Thanks
/ alternator
/ alternator
I assume you are referring to the light on the dash that goes out when the tractor is cranked. That light is constantly red now. Please advise if this is not what you are referring to.
/ alternator #9
With key on and alternator not spinning up lamp should be on, if alternator spins up with engine RPM and light does not go out it indicates alternator is not producing....
/ alternator #10
Most systems utilize a 120A +/- strip fuse or fusible link that may have blown if you shorted the cables or hooked them up backwards while swapping batteries. Check that, if there is one.
Patrick
/ alternator #11
If the alternator is not working you can just replace
the diodes/rectifier cheaper than a new alternator
willy
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
JOHN DEERE 4730 SPRAYER (A64278)
JOHN DEERE 4730...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2010 Chevrolet Express 3500 Dive Team Cargo Van (A64556)
2010 Chevrolet...
2015 Hyundai Elantra Sedan (A64557)
2015 Hyundai...
