alternator
   / alternator #1
cowpens
Mandra 55004wd
Replaced the battery on 5500 mahindra. Alternator not working now.
   / alternator #2
Are you sure it was working right before? That's probably why you had to replace the battery...
SR
   / alternator #3
Out put voltage at B+ terminal of alternate when proper charging should be 14 volts (+/- 0.2 volts).... IF not alternator has a problem... If there is a regulator associated with alternator it could possibly be problem...
Also check if system has a ALT lamp. some systems require a shot of 12 volts through ALT lamp to initialize charging, if lamp is burnt out it may effect how alternator operates....
   / alternator
The light was not coming on before. Not sure about the voltage but will check. Thanks
   / alternator
   / alternator
I assume you are referring to the light on the dash that goes out when the tractor is cranked. That light is constantly red now. Please advise if this is not what you are referring to.
   / alternator #9
With key on and alternator not spinning up lamp should be on, if alternator spins up with engine RPM and light does not go out it indicates alternator is not producing....
   / alternator #10
Most systems utilize a 120A +/- strip fuse or fusible link that may have blown if you shorted the cables or hooked them up backwards while swapping batteries. Check that, if there is one.
Patrick
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2013 INTERNATIONAL SA615 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
2018 Wacker Neuson WL 38 (A52748)
2018 Wacker Neuson...
