Alternator Replacement Kit for the Dynamo on a Kubota B7800
   / Alternator Replacement Kit for the Dynamo on a Kubota B7800 #1
bialecki
Oxford, CT
   / Alternator Replacement Kit for the Dynamo on a Kubota B7800 #2
Have you asked you Kubota parts person if they have one....I put the Kubota Alt kit on my B3030 several months ago...cost approx $200 (includes everything you need.)
   / Alternator Replacement Kit for the Dynamo on a Kubota B7800 #3
YUP! Did mine just a few weeks ago when it was WARM!!!
   / Alternator Replacement Kit for the Dynamo on a Kubota B7800 #4
bialecki said:
I was wondering if there is a direct replacement "alternator" kit to replace the factory dynamo that is standard on the Kubota B7800? Also, I see an after-market alternator that is available on eBay eBay: NEW ALTERNATOR FOR KUBOTA TRACTOR EXCAVATOR & MORE NEW (item 330107789551 end time Apr-16-07 11:14:35 PDT), however, the unit has a built in voltage regulators and I was curious on the wiring of such since the dynamo does not have a built in voltage regulator.
There's the problem! With the "kit" ya get everything you need...alt bracket..alternator...new fan belt...wiring harness...etc. Other wise you'd have to scab together stuff..assuming you have a full electrical schemtic to start with.
Thanks for the direction, I will have to contact Woodbury Tractor, Woodbury Tractor Company, LLC to get get a quote, I didn't realize Kubota had a kit. The beauty of TBN, information at your finger tips.
I do have the full factory manual if a pdf of the wiring schematic is needed anyone?
Thanks,
Dennis Bialecki
   / Alternator Replacement Kit for the Dynamo on a Kubota B7800 #6
High capacity alternator kit for Kubota B7800: B7324 (wholegood listed price 170$) available at your local Kubota dealer.
40 amps
CATERPILLAR D6R XL CRAWLER DOZER (A51406)
CATERPILLAR D6R XL...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
2004 30ft S/A Scissor Pontoon Boat Trailer (A50324)
2004 30ft S/A...
King Ag Cattle Feeder (A50515)
King Ag Cattle...
