alternator pully
   / alternator pully #1
mit
does anyone know how to take off the alternator pully? is there a special vice? i tried with a regular vise and i marred the pully.
   / alternator pully #3
Oops, I'm assuming stuff again.
How is 'this' pulley held on ?
   / alternator pully #4
I bet your going to need a puller.
   / alternator pully #5
A two or three jaw puller to put a little pressure on the pulley then tap close to shaft with brass drift to make it pop loose. Or put alternator in vise or something to hold in place and put two pry bars under pulley close to shaft and work loose.
Penetrating oil before attempting to remove will help.
   / alternator pully #6
Picture of a puller.
   / alternator pully
thank u all for your responce. i have to remove the nut that is holding the pully. i need the shaft to stay tight so i can turn the nut off with a wrench.
   / alternator pully #8
mit said:
remove the nut that is holding the pulley
Then I stand by my first statement, 1/2 impact.
If not available, steady a box end wrench on the nut and smack the end with a hammer handle. Hard.
Grip the pulley with a twisted rag wrapped around it and a pair of gloves.
   / alternator pully
the rag idea sounds good but i would like to use some kind of clamp that could hold it strong. is there some kind of pully holder?
   / alternator pully #10
Strap wrench? Just thinking out loud.
72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
72in Dual Cylinder...
2014 Caterpillar 289D High Flow 2-Speed Compact Track Loader Skid Steer (A51691)
2014 Caterpillar...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A53473)
2022 New Holland...
1985 Ford Ltl9000 Tender Truck (A53473)
1985 Ford Ltl9000...
