Alternator needed for TS1910
/ Alternator needed for TS1910 #1
Skinnymc
I am in need of an alternator for my TS1910. I have charging the battery whenever I have not been using the tractor for the past six months but would like to get this alternator replaced now.
Also, I have a large relay under the dash that is closing as soon as the battery is connected. Looks like a silver box just under the center of the dash. Any idea what this is?
I haven't had much time lately to troubleshoot this and I am still able to use the tractor as long as the battery is charged. Figured I should get it running perfectly before spring.
Thanks,
Alex McKinney
/ Alternator needed for TS1910 #2
Forget the OEM alternator, its too expensive. Use a GM single wire with integrated regulator. They're plentiful, cheap and easy. Any automotive electrical rebuilder can hook you up tell you how to install it.
/ Alternator needed for TS1910 #3
I have a used TS1910 alternator.
/ Alternator needed for TS1910 #4
What are the other 2 wires for on my OEM alternator for? Is there a manual for the TS2200 that may show the wiring?
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
INSPECTION (A65583)
INSPECTION (A65583)
