Alternator install on B-7100
/ Alternator install on B-7100 #1
LHoyer
Danbury,WI
Kubota B7100
Has anyone done this to eliminate the dynamo? And if you have, do you have pictures of what you did? Thanks
/ Alternator install on B-7100 #2
When I built my "Kenbota", I replaced the dynamo with an alternator. IIRC, it was out of a 1987 Subaru Justy. I used that one because it wasn't too much larger than the dynamo and it had a built-in regulator. That and I happen to have one sitting on the shelf. ;)
The first picture is of the install and relative size of the alternator. The second picture is how I connected it. The connections are the same as a GM SI-10 alternator.
/ Alternator install on B-7100 #3
Ops. Here's the second pic.
/ Alternator install on B-7100 #5
No, but the alternator doesn't care what it's used on. :cool:
/ Alternator install on B-7100 #6
The B7100 WSM has detailed instructions on installing a large capacity alternator on a B7100.
For you the important info is how to locate and drive the alternator.
The electrical is much easier now with modern alternators.
Dave M7040
  • Forum B7100 large alt.pdf
