Alternate location for the 425 bucket control
   / Alternate location for the 425 bucket control #1
pequeajim
Platinum Member
New Holland, PA
Power Trac 425
I was using a PT 425 today with the bucket attachment and found the forward/aft control, (under dash on right), to be very awkward.
Has anyone come up with a better solution for this?
Jim!
   / Alternate location for the 425 bucket control #2
For starters look up post # 442489 on 6/11/04 at 04:58 pm titled
" very effective modification .....then " this can be found from my bio under all users posts.
Good Luck
Bill
   / Alternate location for the 425 bucket control #3
This is the thread that Bill was referring to. /forums/images/graemlins/smile.gif
   / Alternate location for the 425 bucket control #5
Another approach
CLICK
Thanks guys. I will check it out.
   / Alternate location for the 425 bucket control #7
Yes Moss that is my tractor now and I really wouldn’t attempt to be without that modification. With out it how would you Curl the mini hoe and lift and or tilt at the same time? If one couldn’t do this the hoe would be less effective. It changes one handed one at a time operation into two hands same time together. I probable have 40 hours in on the hoe and its much more gooder better this way.
   / Alternate location for the 425 bucket control #8
Jim,
I did a very similar modification to my 1845 as NJBILL did and find it much easier to use those attachments that use the aux hyd circuit.
I have also considered adding a dual circuit diverter valve so that I can leave the Quick Attach cylinder hooked up all the time and just activate the diverter to reduce the number of hose interchanges when swapping out attachments.
Neither would be hard to do and will enhance the opperating efficency of your machine.
UNUSED FUTURE X-PG44 44" HYD PLATE GRABBER (A57193)
UNUSED FUTURE...
2002 International 9200i Truck (A55315)
2002 International...
CAT Skid Steer (A50322)
CAT Skid Steer...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
LANDHONOR BS-12-2500G (2) PRONG HAYSPEAR (A57193)
LANDHONOR...
