Alternate idea for converting a pin-on bucket to quick attach
   / Alternate idea for converting a pin-on bucket to quick attach #1
jcrvt
Jeffersonville
Kubota 4610, MF500 Ford 9N,
I finally bit the bullet and added quick attach capability to my Kubota L4610 FEL (model 852). The original bucket is a pin-on and I'm reluctant to go the usual route (cut off the tabs and weld on the QA plate). I'm thinking that a simple (non-invasive) way to convert the bucket might be to weld 2 pieces of 2.25" (0.25" wall) square stock to a standard QA plate so that each would line up to fit in the channel of the tabs where the pins currently attach the bucket to the loader arms. Obviously I'll need to drill holes in the square stock to allow me to reinstall the pins to attach the QA plate to the bucket.
I realize that I'll lose some lift capacity because the bucket will be moved forward a bit, but I seldom carry a full load so I can deal with that issue. Am I missing something that would make this idea unworkable/ill advised?
Thanks in advance for your thoughts!
   / Alternate idea for converting a pin-on bucket to quick attach #2
Lift capacity will be diminished. Curl capacity will be crippled. Kasco used to sell an adapter like that, I know of an older Kubota L series with one. Owner complained about it constantly...
   / Alternate idea for converting a pin-on bucket to quick attach #3
Bite the bullet, and convert the bucket.. The pain of doing that will go away, and you will be left with a good workable system. Bring it over and I will do it for you. (for a small fee):)
   / Alternate idea for converting a pin-on bucket to quick attach #4
Converted my Ford 1920, life is good now. Go from pallet forks to bucket in under 20 seconds.
   / Alternate idea for converting a pin-on bucket to quick attach #5
I added a skid steer connection to my tractor and made a DIY adapter plate for the bucket.
That was over ten years ago,,, it works great.
I really like being able to go get the forks so quickly,,, the fork adapter is also DIY,,
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
CATERPILLAR 255 SKID STEER (A60429)
CATERPILLAR 255...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2004 Mack CV713 Granite Fuel and Lube Truck (A59230)
2004 Mack CV713...
