Alright. I screwd it up good now.
   / Alright. I screwd it up good now.
Just for the record, I am we'll versed in Ac. DC not so much but I do know the colors. Lol.
These fixtures as I just found out are black (hot) and white (ground). What a cluster %#@*. No instructions or schematics in packaging. What a major PITA. I guess we should never assume things. The lights work when I put white to black and black to red. Lol
   / Alright. I screwd it up good now. #32
Glad you got them to work.
Still some unknowns here. According to the other thread, this extra factory circuit under the tool box is connected to the 15A "customer use" fuse. Why was i blowing the 7.5A "Combination meter" fuse when I was hooking them up in reverse polarity?
Also, I blew the main 60A which I still dont understand....
   / Alright. I screwd it up good now. #35
This is a GUESS only but if you hook them up reverse polarity and there is no short circuit protection you have forward biased the diodes and created essentially a short circuit. Remember, this is just a theory not knowing the structure of these LED lights.
As far as which fuse blows first can sometimes not make sense but it may come down to the fuse structure. All fuses are not alike, they have different capacities at which they blow. For an off the wall example we had a condition one time at our plant where a machine was tripping a 1200 amp breaker instead of taking out the 150 amp fuses protecting it. It all came down to the condition that was creating the problem and the reaction time of the protective device.
Steve
   / Alright. I screwd it up good now. #36
I'd send those lights back....I don't like the sound of how they were engineered. It doesn't take all that much to put in a safety to protect against reversed polarity. As for the color code...well...I don't think I've ever seen black as positive in a DC circuit.
   / Alright. I screwd it up good now. #37
That's semi-trailer standard. Black is 'marker or clearance lights'.
Well, that explains that.. I am wondering if there is a voltage regulator and protection circuity (diode protection) inside the lights to protect against reverse polarity (I would not have thought the black to be positive on a DC circuit. it would have been nice for the manufacture to have include a simple application diagram..
James K0UA
   / Alright. I screwd it up good now. #38
White = ground is also used in small truck and trailer connection. No black thou.
   / Alright. I screwd it up good now. #39
Glad you got them working. I hooked mine up backwards but didnt blow a fuse. There must be something else going on there. I agree the lack of instructions can be frustrating.
   / Alright. I screwd it up good now. #40
First post so Hello to every one and a Merry Xmass to all.
May I ask is the body of the work light metal?
If it is have you attached the light to a metal part of the tractor?
If you have then my thoughts are that the earth wire on the light runs to the body or case of the light so by run the Positive wire to the earth wire on the light it will create a dead short to earth through the metal case of the light.
Hope this has helped in some way.
Ford Super Duty Pickup Truck Bed (A55973)
Ford Super Duty...
2009 Dodge Ram 3500 Flatbed Truck (A55973)
2009 Dodge Ram...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
2014 Ag Spray Schaben Sidedresser (A56435)
2014 Ag Spray...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
