Almond Huller
/ Almond Huller
Thank you for taking the time to respond. I do appreciate it.
Almonds have a similar covering to walnuts (both Black and English) and that is what is normally called the "hull". At least that is the word used in California, where I believe at least 80% of the world's almonds are produced, so I use Californian terminology. It is only this hull I want to remove. Again, following California, the hard case is called the "shell", so shelling (also known as cracking in some places) is the next stage to leave the edible part of the nut, and this is called the "kernel". Shelling would be done by the buyer of the de-hulled nuts.
I think pecans have a similar hull, but have never seen one whole. In California there are hulling and shelling operators to deal with the enormous quantity of nuts harvested every year, so they have very complicated machinery.
I thought there had to be some sort of auger type arrangement to move the nuts horizontally along the cage, and as you say, simple beaver tailed paddles, angled to move the nuts in the right direction. Another interesting thing about the last video is that the machine shown there has horizontal cage bars, much easier to fabricate than bending the bar to fit the circle of the cage. The top half on all of them can either be lifted or removed for access to cleaning the cage after use.
The de-huller is not supposed to break the shell, but some of the broken ones may have been damaged during harvest as well as the odd one during de-hulling. The machine shown seems to be a bit short. Longer ones - up to 10 feet appear, do a better job. Probably depends on speed of rotation and throughput I suppose. Not enough nuts and they are not in there long enough to be de-hulled, too many and they are not abraised (is that a word?) enough to take the hull off. Combine harvesters can have the same problem, and the grain is not threshed from the ears.
I do not know the reason for the water. Possibly there was a lot of dust and dirt picked up with the nuts, I should think it makes things stick to the shells rather than clean them. Odd bits of husk in with the nuts "in shell" is not a problem, because the de-hulled nuts can be run over our olive sorting table. This is a table made of round bars (the same idea as the huller) set on legs to give a slope top to bottom, olives are tipped on from the sort of boxes shown in the last video, and the damaged olives, or ones that had died and dried off before harvest, the odd leaf or twig, etc. are quickly picked off by hand. Almonds/walnuts/pecans that still had hulls attached could be removed at this stage quite easily, and either put through the de-huller again, or if they are "stick tights", another Californian expression for hulls which are stuck to the shell, just discarded.
Thanks for the remarks regarding the website. It was made by the neighbour who will be working on the project with me. He is a professional graphic designer, but would really like to be a peasant. He is young enough yet, so should end up OK.
The nutcracker looks good. I have seen a home-made one in the background of a video from either Italy or Greece that I made a note of, that works on the same principle. The hand-cranked huller looks very similar to a gadget I saw for shelling corn. I think they are dual-purpose. Simply not available here. I have not grown corn for four or five years, and had less than acre when I did, so I just shelled by hand on wet winter days.
/ Almond Huller #12
/ Almond Huller
forgeblast, Thanks for your input. As can be seen from your first link (for those who did not know) the nuts are partly released from the hull when it is time to harvest. It is generally recommended to begin harvest when most of the hulls have split. The de-hulling is to completely remove them from this hull. Simple abraision does the job. A little more research indicates that it is normal to apply water when de-hulling walnuts. The size of the nut to be hulled determines the gaps between the bars of the cage. Walnuts are much bigger that almonds and a dedicated walnut huller can have bigger gaps than a dedicated almond huller.
Some of the photos in your second link do show the "beater" arrangement inside. You will note that the cage is similar to those shown in the earlier links, but these ones have a cover over. The last picture is of a tub shaped walnut huller and there are a few videos of these on YouTube for anyone interested.
I will ultimately need to make the decision about which type of internal mechanism to use. I rather like the idea of beaver tail paddles which act as an auger too, but beaters might be easier to fabricate.
/ Almond Huller #14
now this has nothing to do with hulling or shelling, but first you have to pick them up so maybe this will be helpful.
I was surprised at the number of models available.
Quick Find
/ Almond Huller
No, those are for Black Walnuts which are allowed to fall naturally. In the US tree shakers are used to dislodge the nuts from the trees. I will be picking by hand, direct from the tree.
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
KJ K4230G 42'x30' Metal Storage Shed (A60463)
KJ K4230G 42'x30'...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
Adams Under Truck Conveyor (A61307)
Adams Under Truck...
Chandler Equipment 20' Litter Spreader (A60462)
Chandler Equipment...
SET OF (10) ACE CATTLE PANELS W/CONNECTING JOINTS (A60736)
SET OF (10) ACE...
