allternator lb 2202 kioti
   / allternator lb 2202 kioti #1
frank360
Lakeland, LA
Mahindra 2615
trying to find out if 14.4 volts is normal out put all the time are theres something wrong nomatter what rpm speed is it only shows 14.4 all the time. volt meter reads 13 volts before starting useing glowplugs it reads 10volts is all of this normal thanks for any help.
   / allternator lb 2202 kioti #2
It sounds pretty normal. The alternator output during use is usually maintained above 12V as it is maintaining charge and running equipment. The glow plugs would pull it down some. But usually you'll be seeing above 14V. John
2014 Nissan Juke SUV (A59231)
2014 Nissan Juke...
(15) WOOD PALLETS (A60432)
(15) WOOD PALLETS...
2014 Dodge Grand Caravan Van (A59231)
2014 Dodge Grand...
PALLET OF (22) BOXES OF ARMSTRONG TILE FLOORING (A60432)
PALLET OF (22)...
Morgan 26ft Box Truck Body (A59230)
Morgan 26ft Box...
2017 Ford Transit Connect Cargo Van (A59230)
2017 Ford Transit...
