Allmand utility tractor
/ Allmand utility tractor #3
The 8435 gear & HST models are made by TYM, as are the Mahindra 10 series. There was some discussion about them a month or so ago.
</font><font color="blue" class="small">( <font color="blue"> The 8435 gear & HST models are made by TYM, as are the Mahindra 10 series </font> )</font>
This say's Mitsubishi.
Made by Mitsubishi
/ Allmand utility tractor #5
The engine is a Mitsubishi, TYM also uses Daedong, Kubota & I believe John Deere engines as well.
I wonder who makes the rest of the tractor ? I thought I seen something somewhere that the tractor was a Mitsubishi made tractor ,but when I go to the home page the only reference I can find is " Mitsubishi engines"
The TYM tractors .......The 30 to 45 hp range use the Kubota engine, while the 58 to 70 hp range use the John Deere 3029 Engine
/ Allmand utility tractor #7
Actually I can't say I'm 100% positive. It's just that it's extremely similar to the mahindra 10 series with some minor cosmetic changes & obviously the engine. The specs are very similar as well, weight & lift capacity.
I would be willing to bet a TBN shirt if there was a way to confirm it.
/ Allmand utility tractor #8
shvl73
I would think if you saw one in the flesh it will have aTYM tag on it some where.
Happy Tractoring
Chipperman /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
The Allmand tractors use Mitsubishi engines and as far as I can tell TYM only uses Kubota and John Deere.
?? /forums/images/graemlins/confused.gif
/ Allmand utility tractor #10
Kioti motors also, then the whole machine is called the Mahindra 3510 or 4110
2025 X-Pro Victor Mini Dirt Bike (A61574)
2025 X-Pro Victor...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
2007 Blue Bird All American Bus (A61573)
2007 Blue Bird All...
2021 CATERPILLAR 306 CR EXCAVATOR (A64279)
2021 CATERPILLAR...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A61573)
2018 Ram 1500 4x4...
