Allmand utility tractor
/ Allmand utility tractor #3
The 8435 gear & HST models are made by TYM, as are the Mahindra 10 series. There was some discussion about them a month or so ago.
</font><font color="blue" class="small">( <font color="blue"> The 8435 gear & HST models are made by TYM, as are the Mahindra 10 series </font> )</font>
This say's Mitsubishi.
Made by Mitsubishi
/ Allmand utility tractor #5
The engine is a Mitsubishi, TYM also uses Daedong, Kubota & I believe John Deere engines as well.
I wonder who makes the rest of the tractor ? I thought I seen something somewhere that the tractor was a Mitsubishi made tractor ,but when I go to the home page the only reference I can find is " Mitsubishi engines"
The TYM tractors .......The 30 to 45 hp range use the Kubota engine, while the 58 to 70 hp range use the John Deere 3029 Engine
/ Allmand utility tractor #7
Actually I can't say I'm 100% positive. It's just that it's extremely similar to the mahindra 10 series with some minor cosmetic changes & obviously the engine. The specs are very similar as well, weight & lift capacity.
I would be willing to bet a TBN shirt if there was a way to confirm it.
/ Allmand utility tractor #8
shvl73
I would think if you saw one in the flesh it will have aTYM tag on it some where.
Happy Tractoring
Chipperman /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
The Allmand tractors use Mitsubishi engines and as far as I can tell TYM only uses Kubota and John Deere.
?? /forums/images/graemlins/confused.gif
/ Allmand utility tractor #10
Kioti motors also, then the whole machine is called the Mahindra 3510 or 4110
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
2017 Toyota Tundra 4x4 Crew Cab Pickup Truck (A61573)
2017 Toyota Tundra...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
