Allmand TLB425 backhoe
/ Allmand TLB425 backhoe #1
Rike Farms
Allmand TLB-425
Need to replace alternator on my Allmand TLB425 backhoe, the SN is 0021T42502 Trying to determine what year it is or what is the part number for altern
/ Allmand TLB425 backhoe #2
Last 2 digits of serial number is the year it was made
/ Allmand TLB425 backhoe #3
A lot of people are using those universal replacement alternators with the rectifier and voltage regulator built in.
Maybe someone will chime in with the exact information. From the many time I have seen them mentioned in threads here, it is a Datsun type, available at most car parts stores, and priced around $50.
Or if you are a do-it-yourselfer, get out the voltohmmeter and see if it is simply a shorted diode in the rectifier plate.. That's usually the problem.
rScotty
/ Allmand TLB425 backhoe #4
Any numbers on the alternator?
Adams High Clearance 5 Ton Spreader (A63688)
Adams High...
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2001 GMC C7500 Fuel Truck (A62613)
2001 GMC C7500...
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
