Allis Chalmers D17
/ Allis Chalmers D17 #1
jhill61
Lubbock,Tx
1960's Allis Chalmers D17
I bought a D17 that needed the hydraulic pump repaired. I used it before the pump was repaired and it ran and pulled fine. Since then it has not been pulling as well. The last time I tried to use it, it would barely pull itself. It seems the pump is loading the motor up. Any ideas?
/ Allis Chalmers D17 #2
My first thought is I would make sure that all hydraulic levers are in the float or "neutral" position. A lever may be directing the oil flow to a dead end which is loading the engine. If you don't have a lever or valve issue I would consult the mechanic who installed the pump. Is it an early D17 with an internal pump or a series three or four that has the pump externally mounted on the right side?
It is an early 60's. Series I I think. It has an internal pump. I put the pump back in after I had it repaired. The mechanic that checked it out is no longer working at the dealership. My problem here is that I can't find anyone who remembers how to work on tractors that old and there aren't that many Allis Chalmers around this part of the country. The levers are in the neutral position as far as I can tell.
/ Allis Chalmers D17 #4
There is a website I can direct you to that is frequented by Allis Chalmers mechanics and people who work on them. It is Object moved
Go to the farm equipment forum and post your question. They definitely have the knowledge to solve your problem.
Thanks
Thanks I will try that. I appreciate the help.
2004 Chevrolet Silverado 1500 Pickup Truck (A64556)
2004 Chevrolet...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
2022 EZ-GO ELITE...
2007 TORO 3300-D CART (A66091)
2007 TORO 3300-D...
