ALL IN A DAYS WORK!
/ ALL IN A DAYS WORK! #21
HELLO TO ALL,
you say you used treated wood. is that the kind
that destroys the bolts? i have been told this is
what happens if you do not use a plastic tube
between the wood, and the bolt.
any comments on this?
accordionman
wlbrown
Hey Rob,
Thank you for the kind words. I really appreciate your guidance on previous posts and PM's. The OP welding method you mentioned sounds like the way to do it. I'll use that next time. I do have several projects in store and you're right about the ideas flowing!:)
accordionman said:
HELLO TO ALL,
accordionman
wlbrown
William,
I used treated wood and galvanized carriage bolts. I haven't heard about the wood treatment destroying metal. Thanks for the info and I'll look into it.
/ ALL IN A DAYS WORK! #24
MUDONTHETIRES said:
Brian,
The solar panel on this model recharges an internal lithium battery which powers the filter. If not used for a period of time, directions state to recharge the filter by putting the filter under a 60 watt light bulb for one hour. There is no on/off switch nor any adjustment dials for sensitivity or shade. I should have searched the net before "impulse buying". After searching around, I know now that $99.00 could've bought me more options.:eek: I tried charging it again and welding with it. Instead of flickering, now it has two dark streaks through the filter.:mad:
Harbor freight auto darkening helmet for me. Adjusts from #9-#13 shades, strike an arc and your in business. Cheap, light weight, works good.
/ ALL IN A DAYS WORK! #25
After getting one for camp, I bought another for at home. After years of using stock helmets, they are a breeze to work with in comparison. I can actually see where I'd Like to strike the arc!
/ ALL IN A DAYS WORK! #26
MtnView and 3RLL,
Count me in, my son and daughter gave me the HF Autodarkening unit for Christmas, it's great.
Like Rob said, I had also stuck with the stock type for a long time, probably a few years too long. It always seemed to work, so I never pursued the auto-darkening models.
To anyone still using the old stock models, do yourself a favor, you will love the autodarkening!!
/ ALL IN A DAYS WORK! #27
SkunkWerX said:
MtnView and 3RLL,
quote]
Well, the dummy that I am, I used the old std helmets for, uh, well until about a month ago.:eek: 30 some years, I'm not sure if I'm dumb, stubborn, lazy or just plain stupid. What I do know is that I should have bought an auto darkening helmet a looooong time ago.:D
/ ALL IN A DAYS WORK! #29
I am looking to get one that is part of a positive air flow system. I plan on working with some chem's and figure might as well get the flip up helmet for it. I especally like the idea after watching the video of fel hooks being welded on. Not much can be taken for granted these days. :/
/ ALL IN A DAYS WORK! #30
MUDONTHETIRES said:
Thanks Milkman!
I went to Home Depot to get those locking pliers but all I found in that size was $22.00 a piece. I went to HF and picked up four for under $20.00. I know they're low quality but I've used them several times in the last two months practicing my welding and so far so good! While I was there, I picked up an 8' X 8' welding blanket. It sure came in handy covering up my FEL's hydraulic lines!
Hi Mud,
And welcome to the wonderful world of welding. That was a very smart move as far as the pliers go. Even the very best pliers and clamps can be ruined by the heat and splatter of welding. I keep two types of pliers and clamps. One for welding, the other for everything else.
Later,
Wayne
wa9w00d said:
Hi Mud,
Later,
Wayne
Thanks Wayne!
This "world of welding" is starting to get fun! I've got several projects on the agenda. I've used those HF pliers half a dozen times and so far so good! I'll be using them again this weekend when I weld a receiver tube on my bucket.
1996 International Water Truck with a Caterpillar Engine (A63688)
1996 International...
2024 CATERPILLAR 289D3 SKID STEER (A64279)
2024 CATERPILLAR...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2025 GIYI GY-P45 Hydraulic Breaker Skid Steer Attachment (A61572)
2025 GIYI GY-P45...
