Oil & Fuel All fluids change on a Ford 1900
   / All fluids change on a Ford 1900 #11
Neither is right.
Fill till it comes out the hole.
Fill till it comes out of the hole = .23 Qt. On final reduction gear case. It doesn't hold much.
Each gear case, use high quality, extreme pressure gear lube with anti foam agent, temp under 86 deg use viscosity grade 80. over 86 deg, use 90 or 140. My opinion in Kansas for Year around vis 80 should work just fine.
Engine, transmission, (REAR AXLE) not front ,and Hydrolic system use M2C-134-A
Front wheel bearings and all lubrication fittings use Ford M1C-137-A
Front Axle gear case has a dip stick/fill plug on the top of the right side of axle. Drain by removing bottom drain plug. Fill until oil level on dipstick is between mark and tip of dipstick. Use same 80 vis as in front gear cases.
Rear axle is lubed by the transmission and hydrolic fluid in a connected resorvior with the 134A fluid.
   / All fluids change on a Ford 1900 #12
that 134a spec will be superceeded with M2C134D
soundguy
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
toro reel master (A56857)
toro reel master...
2002 Henderson 8X Mild X Sandspreader Attachment (A55973)
2002 Henderson 8X...
4 Unused Montreal ST205/75R15 Trailer Tires (A55787)
4 Unused Montreal...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
