Airtool... how can I decrease RPM without decreasing torque?
   / Airtool... how can I decrease RPM without decreasing torque? #1
Dadnatron
Versailles, KY
JD 5100e with FEL
I have a project in which I need a 'die grinder' type device for power, but I don't want the RPM of a typical die grinder.
I am looking for something to power a cutter which I am designing, but need the RPM to be drastically lower. Tho RPM on the tools I have seen are in the range of 13-20K and I am looking for something in the 500-1000 or even less range. (At least at this time.) However, I still need to keep the torque of the machine to run the cutter. I am afraid, although I don't know for sure, that the high RPM will cause too much heat in the foam I am cutting. (memory foam type material)
I am not familiar with airtool workings. I have and use several, but that is it... I use them. The most I do to them is oil them.
I suspect there is a way to decrease the RPM via orifice reduction etc. But I also suspect that would drastically decrease the effective torque. Otherwise, I suspect I would need to change the internal 'gearing' in some manner, which I am willing to do, if it is reasonably accomplished by a 'novice'. I am pretty handy, and not afraid to take on a task, and I am willing to 'sacrifice' a few HF tools in order to give it a try. But, I don't know where I'd begin.
If you know of a die grinder/cut off tool with either a variable speed or MUCH lower RPM, that might work for me without necessitating all the hassle. I also don't know whether simply turning down the air pressure would decrease speed without torque, although I would think both would be affected.
Straight cutters, saws, hot wires, etc will not work.
I need to be able to slow down a cutoff wheel machine or something along those lines. Something similar to or along the lines of the pic below.
   / Airtool... how can I decrease RPM without decreasing torque? #2
Maybe use an air drill that already turns slower? I don’t know of any way to slow an air grinder without loosing toque short of an external gear box.
   / Airtool... how can I decrease RPM without decreasing torque? #4
I have a large variable speed dremel. But, even variable speed (110V) electic tools lack power when you slow them down as there is not a feedback circuit.
   / Airtool... how can I decrease RPM without decreasing torque? #5
I have a simple inline valve that allows for fine air flow adjustment. But it doesn’t really work well to adjust RPM- it seems to either spin or not spin as opposed to being variable speed.
My thought was exactly what is posted here- find a tool with the correct RPM.
FYI- I thought most foams were cut with an electric knife......like the old school knives you used to cut the turkey with.
The drill might work... but my issue is the handle angle will get in the way of my cutter. If I rotate it out of the way, then my control on the cutter requires 2 hands which takes away usefulness. Otherwise, I could just use a cordless drill. But I wonder whether I could scavenge the guts of the drill and move the important parts to a die grinder or cut off. perhaps just the gearing etc.
I was reading and it appears there might be the possibility that a flow valve will decrease the RPM while maintaining torque. But I'm not sure. Any recommendations on good types of flow valves which maintain constant pressure?
Air Motor Selection and Sizing | Hydraulics & Pneumatics
• Air motor speed can be regulated through simple flow-control valves instead of expensive and complicated electronic speed controls.
• Air motor torque can be varied simply by regulating pressure.
   / Airtool... how can I decrease RPM without decreasing torque? #7
I doubt the drill has gearing except for the right angle gears. I imagine it’s a similar concept to a hydraulic motor where you use a bigger displacement motor in relation to the flow to go slower.
   / Airtool... how can I decrease RPM without decreasing torque? #9
No load speed will be higher than loaded speed, but a simple valve inline will reduce loaded speed without reducing loaded torque.
Aaron Z
   / Airtool... how can I decrease RPM without decreasing torque? #10
in theory... you want a flow control valve... it limits the volume of air flowing without a pressure drop. I use them to control the speed of a pneumatic cylinder, without reducing force.
Sheets of 12' Tin (A53316)
Sheets of 12' Tin...
1827 (A51248)
1827 (A51248)
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
WHISPERWATT DIESEL POWERED GENERATOR (A53843)
WHISPERWATT DIESEL...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
