Airpak 302
/ Airpak 302 #1
brain55
Veteran Member
Brentwood, CA
http://www.millerwelds.com/products/enginedriven/product.php?model=M00458
Considering this for my new mobile shop if/when I upgrade. I currently have a Redi-arc ZR-8 I use it to run my LN-25 wirefeeder. I also have a separate air compressor. Since the compressor in this unit is a screw type it has considerably more output. I will likely add a tig module and plasma cutter too.
Brian
/ Airpak 302 #2
I've heard / read those are really nice machines. I just cringe to think you'll be doing any carbon arcing with it? In the past I've welded with shop machines that have seen a steady diet of air arcing, it sure takes a toll on the quality of arc. Never seen it myself, but several heavy equipment mechanic friends have told me they have seen the cranks broken in engine drives from air arcing. I can believe it though. I've air arced at over 400-amps with engine drives, they sure lug down at first, and blow out the blackest smoke! Seen the leads jump over 2-feet off the ground also!:laughing:
/ Airpak 302 #3
The compressor is nice for air tools too but I wouldn't use it for heavy gouging. Occasional gouging with smaller rods should be OK. The air paks aren't cheap to fix if you abuse them.
/ Airpak 302
I've never done any gouging so I should be okay. It is probably more welder than I need but the compressor with the drier/seperator and the battery jumper/charger makes it appealing to me. Plus it has enough generator that I can use it for redundant power if my generator in the trailer should go down.
Brian
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
SET OF HANG ON QUICK ATTACH 48' PALLET FORKS (A59823)
SET OF HANG ON...
(INOP) 1996 CASE 580L BACKHOE (A59823)
(INOP) 1996 CASE...
John Deere 4510 (A53317)
John Deere 4510...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
