Air Tools
   / Air Tools #11
Prokop,
The air ratchet isn't very useful. They are noise and don't have allot of power. For long threads, they will speed things up, but it should be at the bottom of your list.
A decent impact wrench is worth it's weight in gold. Just think about taking off a tire. Jack it up and squeez the trigger, and your lug nuts are off. Two seconds per nut and they are off. Without, you have to break them free, then jack up the car, and then wratchet them off. There is no effort with the impact wrench.
The same is true for anything else that you can get the impact wrench onto. There is no effort on your part to take off a bolt or nut. My dump truck, dozer and backhoe have bolts that are torqued down to 500 to 700 pounds. I don't care how big a breaker bar you have, you will never get them apart by hand. I use a 3/4 impact wrench with over 1,250 pounds of torque.
My regular impact half inch impact is how I take off the blades for my shredder. With all the moving parts, I have no idea how I'd lock them in place if I had to use a breaker bar. With the impact, it's a ten minute job per blade.
Putting thing back together with the impact is just as fast, but you have to be sure the threads are not stripped and you don't overtighten anything.
My other favorite air tool is the air grinder. I have a metal cutting tip on it and it words great for shaving off bits of metal or getting old parts to fit together again.
If you ever decide to do any woodworking, air nailers and brad nailers will completly change your world. Not the same as impact guns, but there is no comparing how fast and good they are.
Eddie
   / Air Tools #12
Czech, you will find manyuses for air tools, and they are cheap if you do you preliminary assessments using HF stuff, then choose to get selected good stuff. Often they make virtually impossible things trivially easy. If you do any sizable mechanical work buy a GOOD 1/2" impact. The cheapies are sometimes good but this is your basic indespensible. Spend the $1-200 -- dont risk wasteing the $40 on a cheapie. Get a cheap blogun and die grinder. Also a cheap pneumatic hammer and a needle scaler accessory for it. Not sure about air ratchets - - mine just dont get used. It pays to use air tho - it makes life easier.
Larry
   / Air Tools #13
It really depends how your shop is set up.
I have a 1/2" impact, 3/8 rachet, etc. The only problem is that everything is jammed in a garage about 30% as big as it should be, and frequently it is faster to just use hand tools than to get out the air compressor.
For instance, the total time to rotate tires on my car is about an hour with a speed wrench, maybe 30 minutes with the impact. But, getting out the air compressor & putting it away at the end of the job takes 20 minutes and it is hardly worth it. If I had a shop with the air compressor set up permantently it would be a different story.
Carpentry work is entirely different. I will spend an the extra time to use an air nailer, especially a finish nailer even for two or three nails. The reason is that I have never had an air nailer leave a hammer mark on wood, which is something I can't say about my right arm.
   / Air Tools #14
Air ratchets have their place (in the trash can):D . Not really, I used mine alot, but you had to be careful, because when you least expect it, it would tighten up the bolt/nut and slam your hand into frame or some other immovable object. Pinched my fingers on several occasions. But the funniest thing about them is the way they make you dance, when unexpectedly you step on it and it makes that air ratchet noise, you jump like you stepped on a snake or something.
   / Air Tools #15
I don't know about that. I've seen Dad change a lot of semi tires "on the side" from his real tire changing job with only a small ac to re-air the tires after he would change them. I don't remember the name of the tool, but I'm sure he still has it, but you would put it together to form a 4-way type wrench but the "cross" wasn't fixed. You would rock it back and forth to force the lug nuts off or on. I've also seen him use a breaker bar with about 10 or 12' foot pipe on it. What makes this all the more interesting, when Dad would do this (about 15 - 20 years ago) he was 50+ years old 5'10" and weighed about 130 lbs soaking wet - which he usually was after doing this.
   / Air Tools #16
I like my air ratchet best for driving long lag bolts into wood. My impact I rarely use - but all my nailers -- I don't leave home without 'em. So I guess it all depends on what type of "work" you do and how much of it.
   / Air Tools #17
Your guys are entertaining to say the least.:D Repairing the ratchets was a major part of my air tool repair business, and I think anyone in the business will tell they're a pain to work on. But the primary reason so many of them have to be repaired is because obviously most mechanics use them a lot and use them for a breaker bar instead of stopping to get the right tool.:rolleyes: Like EddieWalker said, they don't have a lot of power, but do have a lot of speed. One of my customers was a paint and body shop where the owner had Snap-On's highest priced air ratchet and I replaced the anvil in it 3 times because he hired kids to remove damaged parts on vehicles he was fixing and that ratchet was a long one and the kids simply broke the anvil out of it using it for a breaker bar.
As for them jerking your hand around and skinning your knuckles, yep, they sure will unless you want to spend the money to get an IR111, a "reactionless" ratchet also called the "knuckle saver". It actually has a tiny impact mechanism in front of the air motor so when it gets tight, it starts working as a little impact wrench. Neat tool, but expensive.
And as for it being too much trouble, or taking too much time, to get the air-compressor out, I'm sure that's true for a lot of folks, but that's a problem I don't have because mine stays fully aired up and ready to use all the time. Even if I don't use it for anything else, I use it nearly every day to blow the whiskers out of my electric razor.
   / Air Tools #18
Bird, you hit it before I could say it, my dad has that "impact ratchet" and loves it, his arthritic / carpal tunnel surgery done on each hand loves the air and other impact tools.
I just figure I am lazy, and a tool junky, but I use the air tools constantly. But we do use the air compressor daily so it is always sitting there quietely ready to go. With the landscape equipment I don't think a day goes by without having to air up the tires on something :) I think we did 4 last night, and the DW had to do one or two more this morning she said.
I would say spend the big money on the 1/2" air impact, I grab mine more than any other air tool I think (although lately the 3/8" Impact has been coming close) and the other ones, get decent quality pieces but not the premium if you are just using them occasionally.
   / Air Tools
Eddie:
I hear you about the impact wrench and tires; that makes perfect sense. Air nailer we used a lot when building horse fence, that really makes it go fast. But while helping friend on house framing we used air nailer - and my impression was the hammer actually tightens the wood closer while driving the nail in - the air nailer just zips the nail in and the connection is not as strong.
My opinion only :)
I do quite a lot of woodworking and on wood trim I wished for air nailers already, using a hammer and driver on finishing nails is a major PITA.
I am bit old fashioned in a way - I prefer carpenters axe to a hammer and never got used to american framing hammer.
Bird:
thanks for the idea, I will look into 'reactionless' rachet.
Mikim:
For long lag bolts I use my corded drill
Well, thank you, everybody. It helped me a lot. I already use some power tools - like battery drill - to help with long threaded bolts and it makes only sense to start using the compressor more.
   / Air Tools #20
A friend used to use a roofing hatchet instead of a hammer. Until one day he was in a hurry and picked it up backwards.
Fortunately, his aim was good and he struck the nail squarely with the sharp edge. He nearly fainted right there on the roof, thinking about the fingers he almost lost.
As long as I knew him, he stuck to hammers after that.
UNUSED FUTURE BD43 HYD BACKHOE DIGGER ARM (A54757)
UNUSED FUTURE BD43...
2021 JCB 3TS-8T TELEKSKID SKID STEER (A52705)
2021 JCB 3TS-8T...
(INOP) 2013 INTERNATIONAL WORKSTAR 7500 6X4 DUMP T (A51406)
(INOP) 2013...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
John Deere 853 20ft Corn Head (A55301)
John Deere 853...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
