Air Powered T-Post Driver
/ Air Powered T-Post Driver #1
Anonymous Poster
Epic Contributor
Spring is here and time to start on this new fence....
Though, that means lots of tractor time with the post hole digger!!! /forums/images/graemlins/grin.gif
But also means lots of back breaking corner post work
and hand T-post pounding ick.
Were doing 5 acres for horses with 5ft high non-climb horse fence and 7 ft t-posts with electric tape along the top.
My sincere thanks to the man who made the post hole digger!
Got 15 - of the 8 inch oak corner posts in with my 12 inch auger, (man those oak posts are heavy, must be 200 lbs each?, my FEL did most of the lift work with a chain, whew)
Another 30 of the 5 inch brace posts dug with my 9 inch auger, and every 6 ft another 5 inch post for sturdiness. All held in with Sac-crete concrete argh argh argh. /forums/images/graemlins/wink.gif
1600 lbs of sacrete (80lb bags).... though made easy with the FEL transporting it, just turn tractor around, pull up to the hole and cut the bag, pour 1/2 bag, pour water, dump the rest. Tamp and pack concrete with tamper, check level... Onto next wood post.... etc etc.
Now time for T-posts ick I had drove 25 of them sunday.... this got old quick especially when it was rocky, there must be a better way. Searched the rental places for attachments drivers for the rear of our tractors, no luck... No rental places had a Bobcat post driver either.
Called a fencing company, they'll drive the tposts with there Bobcat post driver, but its $80 and hr. with 400 more posts to go, he said it'll take 5 hours. $400 ouch.
Searched the internet, found hydraulic ones for $2500, ah not.... but I did found this place! Pretty Cool, and air powered T-post driver.
Rohrer - Air T-post driver
I figure for about the same $, I can have something to show for it, and I can use it later on for my other fencing projects.
I ordered it yesterday, will be here next week, just in time for the 400 t-posts arriving this thursday.
I thought I'd share this product with everyone, I'll get more photos of the fence later as I go, how this product works and some tractor time. /forums/images/graemlins/tongue.gif
It seems like a worth while investment in time and money,
and not to mention all that hand pounding, blister making t-post manual driving stuff. /forums/images/graemlins/frown.gif
Btw: I luv my tractor, FEL, and PHD /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
John
/ Air Powered T-Post Driver #2
John, if you have many posts to drive, that looks like a pretty neat tool as long as you have a portable compressor to take along with it.
I'll have to rent a gas air compressor, its rated at 9 cfm.
The driver is 2.2 cfm. The rental is $35 per day at Nuway.
Btw: For those experience Horse fence builders, am I doing everything ok? Anything to change, now is the time....
The t-posts are 6 ft spans, with every 6th post is a 5inch wood post... Is this ok? I'm thinking the electric 1 1/2 tape along the top will keep them out of the fence.
John
/ Air Powered T-Post Driver #4
My Fatherinlaw and I put in about a 100 t-posts in one day using the FEL on the tractor. About 90% of the time the FEL just shoved them right in. The rest took a little persuasion with the t-post driver. A 100 of them may not seem like much to old hands at fence building, but it was a banner day for us. We did a few with the driver and then stood back and said there has got to be a better way. We cut a measuring stick to get the height and used that up against the post while shoving it in. It was wonderful compared to the driver.
Driving them in with the FEL.... did you have the bucket tilted back all the way? that would seem a little dangerous if they slid on the bucket to a side. If the bucket was level, placing it underneath the bucket wouldn't seem like a good idea either.
How heavy was your tractor?
Mine 4300 is only 2900lbs, with loader I think its another 900lbs. I'm working by myself to, so I don't think I could line one up correctly and get it started right. I'm afraid my light tractor would lift the front end off the ground.
If a person had some type of post "catch" or hitch setup where they could catch the post in a secure position from moving side to side or front to back on the FEL, it sounds like a easy way to get the job done using what a person already has.
J
/ Air Powered T-Post Driver #6
</font><font color="blue" class="small">( using the FEL on the tractor )</font>
I've seen that done with a bigger tractor; worked great. So I tried it with my little Kubota and with my hard clay ground, just picked up the front wheels on the tractor and the post hardly make a dimple in the ground. /forums/images/graemlins/frown.gif /forums/images/graemlins/laugh.gif
/ Air Powered T-Post Driver #7
I drive t posts all the time with my tractor. I put some material (dead weight) in the front end loader. Usually I can just push down and that's all it takes. If that doesn't get it then I drop the bucket about six inches at a time. I use the part of the bucket that has a reinforcing strap so I don't dent the bucket.
A thousand pounds dropped six inches can so some damage. /forums/images/graemlins/grin.gif
/ Air Powered T-Post Driver #8
Went over to a friends place to put in a couple hundred yards of chain link fencing. He decided to use his FEL to push the posts in and in they went, with just down action of the loader. Made me a little ill to not drill a hole and set the posts in concrete but it was his fence and my day off work. /forums/images/graemlins/wink.gif
/ Air Powered T-Post Driver #9
Were the oak posts treated or untreated?
I got them from MFA, they appeared to be untreated (maybe).
The kid that sold them to me didn't know. Orshelens had some creasoaked ones, but they were out of stock on the 8" and didn't know when they would get more in.
Would treated Oak have a certain color?
Whats the life of treated vs. non treated?
Can I spray something on them to make them last?
John
/ Air Powered T-Post Driver #11
</font><font color="blueclass=small">( I'll have to rent a gas air compressor, its rated at 9 cfm.
The driver is 2.2 cfm. The rental is $35 per day at Nuway.)</font>
Picard335, I just came across this PTO air compressor kit from Norther Tool for $149.99 and thought of you. I've also attached a pic of the unit.
/ Air Powered T-Post Driver #12
I've put in 4 acres of horse pasture using 1 inch electric tape, 4x4 for corner posts and t posts w/ pvc covers for line posts. Had some success pushing them in with the loader. Works a lot better if you slip a post driver over the top, THEN push down with the loader. Gives you a lot bigger surface area to psuh on and retards the tendency of the bucket to slip off the t post. You do need soft ground and some weight and it's a little harder to insure they go in plumb. Make sure you get a large charger, you want them to get a good solid zap when they hit the tape, we had to upsize our charger after we added two more pastures, the zap just wasn't discouraging enough, especially as summer progresses, the ground gets dryer and the ground diminishes. Big difference with the new charger!! You also might consider putting it not right on top but about 4 feet high on the inside. They make the clips that hold it out from the surface 2 inches. That way they can't lean on the fence to scratch or they hit the tape. If they lean over the top they still hit the tape. If you run a strand on top they can still sidle up to the fence without hitting the tape. After all that work I don't think you want a 1200 hundred pound animal using your handiwork as a scratching post!!
/ Air Powered T-Post Driver #13
Post life.
Oak posts will last from 5 to 10 years if they're untreated. Treated you'll get a longer life. The problem is the density of the wood and how well it responds to the preservative treatment. Oak probably doesn't accept a preservative as well as southern pine.
For your purposes, I would spend the money on the best posts I could get for corners and pull posts. Osage orange if you can find it will last 50+ years with no treatment. Black locust is good. Untreated it should do 40 years. If any Amish live near you, check with them for posts.
The question is how often you want to redo the fence. If you have untreated oak posts, you might be out there in five years putting parts of the fence back up. When your corners and pull posts rot out, your fence is shot.
Setting posts in concrete is somewhat controversial. Some folks believe the concrete will hold moisture around the posts and cause them to rot faster.
/ Air Powered T-Post Driver #14
Re: Post life.
Oh 'fence' post life !!!!
I thought someone had a project in the afterlife. That would have been an interesting post /forums/images/graemlins/wink.gif
Spencer, cool pto compressor! thanks, wonder if it accept standard air compressor 3/8 or 1/4 hoses and connectors?
Great idea /forums/images/graemlins/wink.gif
Thanks for the Ideas Gerald, really appreciate it....
I've got the 1 1/2 tape for the top, and I'm thinking 1/2 electric tape about 3-4 ft up.
I bought a Solar 3 mile fencer, what do you think? There is no electric there, am I better getting a battery 6v or 12v system? but they only last 5-6 weeks what the box states. Where fencing about 4.8 acres
Darren, I'm gonna call MFA to see if there untreated, I hope they are treated.... I don't wanna be messing with this in 5 years!
John
/ Air Powered T-Post Driver #16
Can't speak for the solar - just don't know. I have mine hardwired. Being in Syracuse, the second cloudiest city in the US, I wouldn't even consider a solar!! I would think with a solar or battery unit the big variable would be how many times the fence gets hit and you would have to make sure it doesn't ground out anywhere. (If you have the tape low and weeds grow up and touch it it shorts to ground, if hardwired it just reduces the effectiveness a little but a solar/battery unit would draw down pretty quickly I would think.
/ Air Powered T-Post Driver #17
Before you plop down your $450 for the air powered driver you should talk with a local fence company and to get their opinion on whether this driver will be adequate for the soil conditions in your area. This particular driver looks pretty smal. If you can easily drive the posts with a 35# hand driver then it would probably work but you said you were having trouble with rocky soil in some areas. You don't want to have to use the air powered driver like a manual one on the hard holes! The local fence company here has a lot of air powered drivers ranging in size from small like this one to some much larger ones for much larger prices. I know I spent a lot more money than I would have liked by buying too small a tool and then having to spend more to get the right size tool. Funny that the more expensive tool does not seem that expensive after you break you pick trying to use one that is too small.
Heres an update on my fencing project, got all approx 300 7 1/2 ft tall t-posts in the ground saturday, I rented a gas air compressor for $35 a day, I was expecting to take the 3 day weekend, but I did it in 8 hours! Everything worked flawlessly, quite the piece of equipment to have. What can I say, but its a lifesaver!
I towed a small trailer behind the tractor, put the compressor, tools and a bunch of tposts and went to town, even in rocky soil, it had to no problem driving them down, on soft soil about 6-8 hits down. On nothing but rocky about 25-30 hits. On average most took about 10 hits. I'd started to put them in the ground about 3 notches on the post, then stop, check the level, and continue on.... just like that.... everything came out really nice and level and straight.
Very Cool
John
Pic 2
Pic3
These are just pictures from the road, so its only looking at 1/4 of the whole project.
2025 JMR Tree Boom Mini Skid Steer Attachment (A59228)
2025 JMR Tree Boom...
2022 Fairbanks Nijhuis Commercial and Industrial Water Supply Pump (A59228)
2022 Fairbanks...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2019 PETERBILT 389 TANDEM AXLE SLEEPER (A59905)
2019 PETERBILT 389...
