Air in water lines
/ Air in water lines #21
I've had the same problem as hbaird a couple of times in the past fifteen years. My tank doesn't have a bladder either. Common in this area as a way of eliminating sulphur smell by letting the water contact air in the tank.
The float hbaird refers to is called the air control valve. It is adjustable/replaceable, and regulates the amount of air that will be let into the tank as the tank level drops and then goes back up. In my case, the iron in the water cakes on the float mechanism causing it to stick.
If the air control valve isn't working properly, you can get quite a lot of air in the pipes. I had enough air to turn my shower into a "mister" at some times.
Ira
/ Air in water lines #22
An easy way to test the well is simply vent the air out of your tank a few times. This will allow either water and air or air to be pumped to the tank. I do this by unscrewing
,partially, the pressure guage and then retightening it. CAUTION the tank pressure will blow the gauge a long distance and can cause serious injury if it comes loose. Allow the pressure to vent before the guage is completely unscrewed. If the problem goes away for a while, check for the float assembly.
hbaird
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
3144 (A63117)
3144 (A63117)
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
2716SFL (A61567)
2716SFL (A61567)
Black Widow 2 Seater GoKart (A62613)
Black Widow 2...
