Air in lines?
/ Air in lines? #1
DeltaBravo
Dallas, Texas
Kubota L3800 HST
When hooking up a hydraulic cylinder with lines attached for the first time, should you prime the cylinder/lines with hydraulic fluid? If not, where does the air in the lines go?
/ Air in lines? #2
It will flow through the system and get released in the hydraulic tank. You can save some time by adding some oil to the cylinder if convenient to do so. Otherwise it will purge when you operate the cylinder.
/ Air in lines?
Great! Thanks for the reply. I wasn't sure if it would act like disc brakes with air in the lines. Thank you!
/ Air in lines? #4
I have added several cylinders,never pre-filled.The newer tractors are self priming.
/ Air in lines? #6
To speed up not getting a lot of air in the system, just level the rod end hose off and run cyl out then hook up rod end hose.
2009 Jaguar XF Sedan (A61574)
2009 Jaguar XF...
300 GALLON PORTABLE FUEL TANK (A64280)
300 GALLON...
Caterpillar 215 Excavator Parts and Service Manuals (A63117)
Caterpillar 215...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
2020 International HX620 Quint Dump (A62613)
2020 International...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
