Air in lines?
/ Air in lines? #1
DeltaBravo
Dallas, Texas
Kubota L3800 HST
When hooking up a hydraulic cylinder with lines attached for the first time, should you prime the cylinder/lines with hydraulic fluid? If not, where does the air in the lines go?
/ Air in lines? #2
It will flow through the system and get released in the hydraulic tank. You can save some time by adding some oil to the cylinder if convenient to do so. Otherwise it will purge when you operate the cylinder.
/ Air in lines?
Great! Thanks for the reply. I wasn't sure if it would act like disc brakes with air in the lines. Thank you!
/ Air in lines? #4
I have added several cylinders,never pre-filled.The newer tractors are self priming.
/ Air in lines? #6
To speed up not getting a lot of air in the system, just level the rod end hose off and run cyl out then hook up rod end hose.
2016 Deere 180G (A60462)
2016 Deere 180G...
2014 Dodge Charger Sedan (A61574)
2014 Dodge Charger...
Ford Pickup Truck Bed (A61573)
Ford Pickup Truck...
2020 Takeuchi TB250-2 Mini Excavator (A62613)
2020 Takeuchi...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
