Air in lines?
   / Air in lines? #1
DeltaBravo
Dallas, Texas
Kubota L3800 HST
When hooking up a hydraulic cylinder with lines attached for the first time, should you prime the cylinder/lines with hydraulic fluid? If not, where does the air in the lines go?
   / Air in lines? #2
It will flow through the system and get released in the hydraulic tank. You can save some time by adding some oil to the cylinder if convenient to do so. Otherwise it will purge when you operate the cylinder.
   / Air in lines?
Great! Thanks for the reply. I wasn't sure if it would act like disc brakes with air in the lines. Thank you!
   / Air in lines? #4
I have added several cylinders,never pre-filled.The newer tractors are self priming.
   / Air in lines? #6
To speed up not getting a lot of air in the system, just level the rod end hose off and run cyl out then hook up rod end hose.
2015 HINO CONVENTIONAL TYPE TRUCK (A52472)
2015 HINO...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
434669 (A48836)
434669 (A48836)
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
