Air in hydraulic lines
/ Air in hydraulic lines #1
Conservation
Did a search, and am sure that this has been covered before.
But I did some work to my tractor and obviously introduced a lot of air into the lines. I'm struggling to get it out. What is the best way/method?
/ Air in hydraulic lines #2
As you work the hydraulics, the air should be purged. Activate everything hydraulics until everything feels normal.
/ Air in hydraulic lines #4
I have busted a bunch of hydraulic lines on mine and never had a problem with air. Just cycled the cylinder a couple of times and the air was gone.
Found it! I'm sucking air. One of the rubber return line areas. One more thing to fix!
Thanks.
