Air Filter Modification Question
/ Air Filter Modification Question #11
Don't sweat the hot engine air theory, most (all?) dozers have pusher fans that blow out the front so the big honking engine fan is actually sucking cold air across the filter intake.
considering the life of the machine, and that filter element cost when dirty, I can't imagine not being able to completely fab up a new canister for the price of a few years of filters.
considering if you hit a real dirty dusty job, you can clean an oil bath and renew every 6 hours if needed, for about 1.30$ of oil.. vs 11$ per change on the air filter.
anyway.. Like I said.. your machine, ok to do whatever you want to do with it. For sure it's going to be GOOD to have a filter on it, even if non oem. unfiltered air is bad, filtered air is good. if it's enough air flow, and the filtration media is the correct size..e tc. should be ok.
soundguy
How much did it cost for you to fabricate and install oil bath air filters on the NH7610 and Yanmar?
/ Air Filter Modification Question #13
they didn't come with oil bath.. they came dry element, and i left them dry element.
I see you must have missed the point in context here. i'm not advocating converting all dry filters to wet filters, I was mentioning the possibly unknown virtues of the wet filter, on a machine that was originally wet filtered, and was being converted to dry filter.
Apples and oranges difference as to your question of converting a dry filter machine to wet filter, which again, I was not advocating.
I was merely trying to let you know the advantages of the wet. .. but since you want to get confrontational about it.. no problem.. I'll just add you to my ignore list, remove this thread from my subscription list and then go on to read some other emails.
have a great day :) !
soundguy
soundguy
I'll assume you won't get this, but I'll still post for the casual reader:
I was not trying to be hostile; I was just checking to see if you had had an oil bath filter fabricated - you had estimated that the cost would be cheaper than a few years of paper element changes, so I was supposing that you had performed this modification to something.
As mentioned before, this very engine (Case D188) was available with a paper element filter; so while I am converting it from an oil bath filter, the manufacturer also made it that way as well; I just can't find the entire assembly for it, so I'm having to improvise.
I apologize for making you feel like you have to take your ball and go home. You are one of the posters that I generally look forward to "seeing what you have to say." I'll still read your posts even if you can't read my replies, I supppose.
Also, in fairness, I was never questioning the viability of changing from oil bath to paper element - that had already been decided. The question centered around the positioning of the cold air intake (underhood or above hood).
Good luck and take care.
/ Air Filter Modification Question #15
My Case 530 has the oil bath filter, it was a strange thing I had to do some research to understand how it works. Very well. The 530 doesn't stick out of the hood, the intake is right under the hood, I assume that would be the place to find the least amount of dirt there.
I would think paper would not last long when doing dirt with with a dozer.
I can appreciate it if its totally shot, but you could wrap the outside with fiberglass to seal it up if that is all that is wrong with it.
The mesh is available. My unit looked to be an aftermarket replacement.
jack
I'm in the process of replacing the air filter assembly on my old Case 310 dozer. It originally had an oil bath filter (great big canister with a wire mesh in it and the bottom has a detachable cup that is filled with oil, just in case anyone is unfamiliar). (Edit: because it leaked and was becoming a water bath filter).
I looked up what type of "paper element" filters went with my dozer or other vehicles with the same engine, and it seems as though the required CFM is somewhere around 125 to 150. So I went off to the junkyard and looked until I found an air filter assembly off of a Nissan forklift - it turns out its filter flows up to 275 CFM, so I think I'm good.
I can physically fit the filter assembly in close to the same place as the old one, but it is much smaller. The old assembly was bascially an 8" diameter by 18" tall cylinder, mounted vertically. The new unit is about 8" diameter but only about 10" tall, again mounted vertically.
The old unit protruded through the hood of the dozer (through a hole - this was factory design). The new unit will fit under the hood and I would like to cover up the hole and weld it shut. This would make a nicer looking hood and one less thing to get hit by branches when I'm clearing treees.
The old assembly had the precleaner intake (a little gizmo that lookes like a mushroom with screen around it) mounted on top of the old filter assembly. Of course, it was out in the open air. The new assembly has it's intake coming out the side of the filter assembly, so the precleaner would actually be drawing air from beneath the hood, if I don't change anything. So I say all of the above the pose this question: can the precleaner draw air from beneath the hood, or does it need to protrude above the hood.
The dozer's engine is open on each side, so there is nothing to restrict air flow over and above the engine to where the new air filter assembly intake would be. I can't imagine that there would be a problem putting the precleaner under the hood, but thought that I could run it by the brain trust first.
Thanks for your help.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
2014 American Signal Solar Towable Message Board (A59228)
2014 American...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59908)
2017 FREIGHTLINER...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
TraxMax Stand-On Tracked Sod Installer (A59228)
TraxMax Stand-On...
