Air Filter Modification Question
/ Air Filter Modification Question #1
rtimgray
I'm in the process of replacing the air filter assembly on my old Case 310 dozer. It originally had an oil bath filter (great big canister with a wire mesh in it and the bottom has a detachable cup that is filled with oil, just in case anyone is unfamiliar). (Edit: because it leaked and was becoming a water bath filter).
I looked up what type of "paper element" filters went with my dozer or other vehicles with the same engine, and it seems as though the required CFM is somewhere around 125 to 150. So I went off to the junkyard and looked until I found an air filter assembly off of a Nissan forklift - it turns out its filter flows up to 275 CFM, so I think I'm good.
I can physically fit the filter assembly in close to the same place as the old one, but it is much smaller. The old assembly was bascially an 8" diameter by 18" tall cylinder, mounted vertically. The new unit is about 8" diameter but only about 10" tall, again mounted vertically.
The old unit protruded through the hood of the dozer (through a hole - this was factory design). The new unit will fit under the hood and I would like to cover up the hole and weld it shut. This would make a nicer looking hood and one less thing to get hit by branches when I'm clearing treees.
The old assembly had the precleaner intake (a little gizmo that lookes like a mushroom with screen around it) mounted on top of the old filter assembly. Of course, it was out in the open air. The new assembly has it's intake coming out the side of the filter assembly, so the precleaner would actually be drawing air from beneath the hood, if I don't change anything. So I say all of the above the pose this question: can the precleaner draw air from beneath the hood, or does it need to protrude above the hood.
The dozer's engine is open on each side, so there is nothing to restrict air flow over and above the engine to where the new air filter assembly intake would be. I can't imagine that there would be a problem putting the precleaner under the hood, but thought that I could run it by the brain trust first.
Thanks for your help.
/ Air Filter Modification Question #2
There shouldnt be a problem with that other than it will be drawing in a lot of hot air from the engine which will marginally reduce your HP. Cold air expands more when mixed with combustion gases and therefore gives more power than hot air mix. You will also likely be in a dustier environment down low versus up high like the original equipment and will require more frequent cleaning of the filter.
All manufacturers (except maybe the Kubota RTV guys) put the air intake where it can draw in the freshest and coolest air but that doesnt mean that you cant use yours where it is.
Good thought on the cool vs. warmer air - I might just put a 90 elbow on and run the precleaner up through a smaller hole in the hood.
Thanks.
/ Air Filter Modification Question #4
IMHO.. I wouldn't convert from the very efficient oil bath air filter to a paper element style.. but that's your call.
I'd fix the existing unit that leaks and use it... engine made it this long with that style of filter.. must be junk and not function correctly right?? :(
soundguy
The engine was also available with a paper element; so at some point, just a couple of years after my dozer was made, Case (the manufacturer) chose to change to the (more inefficient) paper element; I'm assuming oil bath was probably more "in style" at the time. In later model years, my same unit was available with a paper element later in it's life. I could not find a complete unit to purchase, so I had to improvise.
The existing unit is basically beyond repair - the cannister itself is cracked and damaged all around it -that is where the water is getting in - a lot of the wire mesh is also missing.
I've heard that oil bath filters are better - then why do manufacturer's not use them very much any more? (I'm asking - I really don't have any idea). Some of my older equipment works fine with the oil bath filters, but the filters themselves are in good shape.
Thanks.
/ Air Filter Modification Question #6
So how much money do you think the dealer makes selling you a half quart of oil for your oil cup, vs selling you a 30-60$ dry element, or dry element(s) for the dual element filters.
yep.. was a time saver for the manufacturers in servicing, and a way to make money selling you a consumable.
that filter media metalic floss is very available and if the cannister is metal.. it can be repaired or re-fabricated...
soundguy
I agree with you 110% on the cost of a paper filter vs. oil bath, and I'm sure that is a motivating factor.
The filter assembly that I purchased from the junkyard cost $20. A new Wix filter for it costs $11. There is no way that I can repair/have the unit repaired for anywhere near this amount. I might have to buy one filter per year. The new unit will allow for plenty of CFM to the engine, through a modern filter element. If I were interested in keeping the dozer even somewhat original, your idea would be valid - it's just not for me.
Thanks.
/ Air Filter Modification Question #8
You may /may not have an issue getting the carb tuned with the paper filter. My old case 310 (upflow carb?) wouldn't run less than full choke with the oil bath intake hose off. I'm not sure the paper element has similar amount of "restriction".
Mine's a diesel - sorry for leaving that out.
/ Air Filter Modification Question #10
Thanks.
considering the life of the machine, and that filter element cost when dirty, I can't imagine not being able to completely fab up a new canister for the price of a few years of filters.
considering if you hit a real dirty dusty job, you can clean an oil bath and renew every 6 hours if needed, for about 1.30$ of oil.. vs 11$ per change on the air filter.
anyway.. Like I said.. your machine, ok to do whatever you want to do with it. For sure it's going to be GOOD to have a filter on it, even if non oem. unfiltered air is bad, filtered air is good. if it's enough air flow, and the filtration media is the correct size..e tc. should be ok.
soundguy
/ Air Filter Modification Question #11
Don't sweat the hot engine air theory, most (all?) dozers have pusher fans that blow out the front so the big honking engine fan is actually sucking cold air across the filter intake.
soundguy
How much did it cost for you to fabricate and install oil bath air filters on the NH7610 and Yanmar?
/ Air Filter Modification Question #13
they didn't come with oil bath.. they came dry element, and i left them dry element.
I see you must have missed the point in context here. i'm not advocating converting all dry filters to wet filters, I was mentioning the possibly unknown virtues of the wet filter, on a machine that was originally wet filtered, and was being converted to dry filter.
Apples and oranges difference as to your question of converting a dry filter machine to wet filter, which again, I was not advocating.
I was merely trying to let you know the advantages of the wet. .. but since you want to get confrontational about it.. no problem.. I'll just add you to my ignore list, remove this thread from my subscription list and then go on to read some other emails.
have a great day :) !
soundguy
soundguy
I'll assume you won't get this, but I'll still post for the casual reader:
I was not trying to be hostile; I was just checking to see if you had had an oil bath filter fabricated - you had estimated that the cost would be cheaper than a few years of paper element changes, so I was supposing that you had performed this modification to something.
As mentioned before, this very engine (Case D188) was available with a paper element filter; so while I am converting it from an oil bath filter, the manufacturer also made it that way as well; I just can't find the entire assembly for it, so I'm having to improvise.
I apologize for making you feel like you have to take your ball and go home. You are one of the posters that I generally look forward to "seeing what you have to say." I'll still read your posts even if you can't read my replies, I supppose.
Also, in fairness, I was never questioning the viability of changing from oil bath to paper element - that had already been decided. The question centered around the positioning of the cold air intake (underhood or above hood).
Good luck and take care.
/ Air Filter Modification Question #15
My Case 530 has the oil bath filter, it was a strange thing I had to do some research to understand how it works. Very well. The 530 doesn't stick out of the hood, the intake is right under the hood, I assume that would be the place to find the least amount of dirt there.
I would think paper would not last long when doing dirt with with a dozer.
I can appreciate it if its totally shot, but you could wrap the outside with fiberglass to seal it up if that is all that is wrong with it.
The mesh is available. My unit looked to be an aftermarket replacement.
jack
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2021 CATERPILLAR 289D3 SKID STEER (A62129)
2021 CATERPILLAR...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
