air conditioner
/ air conditioner #1
turdy
canova sd
jd 4450
cant seem to get the compressor to start
/ air conditioner #2
On your 4450? Low pressuse switch? Have you checked to make sure it has freon in it? Check the little square thing mounted in the wire about 6 inches back from the compressor plug. Its a fuse. Make sure you have power through it and into compressor.
/ air conditioner #3
I agree on checking Freon. Also could be a loose circuit breaker located just in front of dash on LH side if it's a JD 4450 in your profile.
Here are some similar links:
  • Article
  • Type: Construction
Replies
0
Views
108
  • Article
Replies
0
Views
85
  • Article
Replies
0
Views
83
  • Article
Replies
0
Views
91
  • Article
Replies
0
Views
88
