Air Compressors
/ Air Compressors #1
BAC
Michigan
TC25D
I have a chance to buy a Puma air compressor, 60-gallon tank, 7hp, two pistons single stage but I have not heard of this brand before. I have done a search but did not come up with anything about this brand. Does anyone have any experience with the Puma compressors? I can get this thing at a very good price.
/ Air Compressors #2
Try this thread
<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=oil&Number=208827&page=&view=&sb=&o=&vc=1>air compressor oil</A>
I did a search on "puma"
A tip on searching, start with less words & then add detail only if there are too many results. IE "puma" vs. "puma air compressor" Also try the "AND" vs. "ENTIRE PHRASE" option.
/ Air Compressors
Thanks for the advise.
/ Air Compressors #4
If you read the thread Hazmat referred you to, then you already know I used a Puma for several years and was very happy with it. The only reason I sold it was because I sold the farm and moved back to town.
/ Air Compressors #5
They are sold locally and have a very good reputation from what I hear... I've shopped them and they look to be well made. HTH...
/ Air Compressors
Thanks for the additional information. I can get this unit for $499. I even think I can get it for less if I dicker a little. I think I am going to go pick this one up. Thanks again.
/ Air Compressors #7
That's a good price. I don't think you'll ever regret buying it.
/ Air Compressors #8
they are a pretty decent unit, don't know what your needs are for it just make sure it will del. the CFM @ THE PSI U REQURIE.
/ Air Compressors #9
Puma Air web site.
<A target="_blank" HREF=http://www.pumaair.com/third.htm>http://www.pumaair.com/third.htm</A>
500 GAL WATER TANK (A68842)
500 GAL WATER TANK...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
Unused 2022 HLA 60in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
2014 FORD ESCAPE (A66091)
2014 FORD ESCAPE...
MIRRORS, MARKER LIGHTS, SWITCHES (A64276)
MIRRORS, MARKER...
